New ES2 Indian-made take knee grip screw holes
HelloI've acquired an Indian-made tank for my 51 ES2 and it seems to be working fine ...all the fuel is staying on the inside where it belongs.the knee grip screw holes appear to have metal plugs in them and are chromed over during the manufacturing processQuestion: do these simply thread out ?do I need to thread a small diameter bolt with a jam nut into the hole to get enough grip to rotate them or do they come out easily without damaging the knee-grip screw threads ?any advise would be appreciated before I attack this with a 5 pound hammerthanksGrant MacNeill, TorontoAttachments
img_2987-jpg
Hey,
Those are normally welded in so be careful. Are the holes not already threaded for the knee grip screws?
B
Previously Bryon Harvey wrote:
Hey,
B
Thanks Byron, What I think I see is the outline of the threaded hole @ 5/16 diameter which matches the kneegrip screws I got from the NOC then there is an inside hole of about 3/16 which appears smooth. as if they used a piece of threaded pipe to prevent chrome plating build up on the threads. (see photo attached) I am assuming that I have to spin this blank out but just hope to hear from somebody in the NOC who knows this for sure.
Worst case, I'll carfully drill out just under diameter and see if I can clean it out with a dentist's pick and the correct thread tap
I can grasp that the threaded part would be brazed into the tank but surely the plugs are just dry theaded in ?
cheers, Grant
I hope you haven't started drilling or anything as that looks correct. The hole should be threaded, it's not a plug. Here's my original 16H tank with a similar tube welded in for the knee rubber fixing.
[IMG]http://i1080.photobucket.com/albums/j331/Horror/IMAG1101.jpg[/IMG]
You might find you need a different sized screw than your original ES2, they may have done the holes for the same size as the 16H. I would contact the seller and asked them what size and thread screw they've done it for.
Hard to judge scale from a pix but it looks to me that the hole is too big for standasrd sized screws. I think Dave has the best idea. Contact the seller and ask WTF?:)
Cheers,
B
Hello I would Not go down the 5 pound hammer route has your tank will then leak , the original threds were BA. now its what the Indian makers have used that counts here, they could well be Metric size its finding the right thred size and pitch , you counld email the makers and try find out this, Yours Anna J
here is a better photo to show the hole in my new tank...it appears to be a smooth hole and not threaded on the inside
Grant
img_2990-jpg
Grant
Two more photos showing my NOC tank screw and teh corresponding hole. Hopefully somebody out there has installed a new Indian made tank and can advise me on this. Grant
img_2992-jpg
Grant
img_2991-jpg
Grant
Hole with No threads well you need the right tap to thread it up with like a BA size tap and screws to match but when using a tape you only need to take some two or three turns at a time then screw back to let the chippings out, and be very careful to has go to far can lead to a leak in the hole , so now it all up to you, yours anna j
I have just gone out to the garage and measured both the 16H and ES2 tank rubber screws, they are both cycle thread BSC the 16H is 9/32" x 26 tpi and the ES2 is 5/16" x 26 tpi, not BA. These replica tanks are made for the 16H and ES2 and I can't see these people changing the thread size to suit each model. I would double check there isn't a thread deeper inside the hole, in case there's a smaller hole inside like 6mm. Otherwise you'll have to cut a thread as already suggested, but it sounds like the tube isn't wide enough for your 5/16ths screws. You'll then be able to cut whatever thread you can get suitable screws for. I had my 16H ones made out of stainless as I couldn't find any.
[IMG]http://i1080.photobucket.com/albums/j331/Horror/DSC_0112_zpsnyiz08rr.jpg[/IMG]
The WD16H and Big 4 spares lists are quite useful as they include fastener sizes. Both these bikes used the single fixing knee grips and both are quoted as 5/16" x 26tpi.
This ties in with the tanks that I have. As original, the bosses were threaded all the way.
Hi Rik, your 16H has 5/16" screws? That's interesting to know. Mine is definitely 9/32" as the 5/16" is too big. I'll check my other WD tank but I'm sure it's the same, I wonder what year they changed?
thanks Dave
I've measured three times...the holes are 7/32 and my NOC screws are 5/16 ... thead nicely into my new Tracy 5/16 x 26 die.
this is the second tank from Vintage Spares in India and I find them the most responsive and willing to answer questions and modify orders to suit. but can't get a response on this knee grip screw question.
I'll probably turn down two of my spare NOC 5/16 knee pad screws as their polished flat-head heads look lovely. will have to use whatever tap and die combination seems to be the least risky. lots of depth in the hole so no fear of bottoming out and penitrating through to the petrol side. and the threaded bush is about 5/16 overall diameter so that leaves me several options for tap size.
happy enough riding around without the pads so I'll see if the guys in India get back to me ...give it another day. I assumed there would be lots of members who had used these repro tanks and a simple answer would be forthcoming. Go figure
thanks for the input, Grant
Looks like they have forgotten to tap the holes! Your pads look new! Reminds me of my experiance with new rubber pads (probably Indian manufacture) where, unlike the originals,they did not have the large metal washer moulded in underneath where thetwo screwsgo through. Once mounted on to my tank, the screwheads would simply pull through the hole in pad. I ended up running a bead of black Silastic all around under the rubber edge, and glued them on in position. Tying some string around them to pull around the curve of the tank till the Silastic set. The screws are now only ornamental. Any excess Silastic can be wiped off with a petrol rag.
I personally would be very carefull tapping a thread into those blank nuts, you just don't know howstrongly they are fixed in the tank side dimples.
Dave, Mine are definitely 5/16" x 26tpi.
It occurs to me that after the WD bikes lost their knee grips due to the rubber shortage, the bosses were used for mounting the tank-top air cleaner. Just possibly they might have had smaller screws....and many of those late-war bikes with air cleaners went to India and the Far East. Could they have copied one of those ?
You've got me investigating all my rigid/plunger tanks now. Both my WD16H tanks are 9/32" screws and 1 OHV tank is also 9/32". This tank only has a 1 1/2" cuttaway for the rockerbox and has 45 stamped underneath. This came to me with my 45 dated Model 18 engine (stamped A3). My other 2 OHV tanks are 5/16" screws with a 2" cuttaway. Odd that one of these tanks has pump fixings.
It looks like they changed to 9/32" late war and early post war, then back to 5/16ths.
[IMG]http://i1080.photobucket.com/albums/j331/Horror/DSC_0095_zpsyesbpcjd.jpg[/IMG]
[IMG]http://i1080.photobucket.com/albums/j331/Horror/DSC_0101_zpsoft7kirn.jpg[/IMG]
[IMG]http://i1080.photobucket.com/albums/j331/Horror/DSC_0115_zps2s4nftz6.jpg[/IMG]
thanks Dave
Mystery solved: I was picking through some old bolts from my 51 BMW (please excuse me for using those initials on this august Norton forum)...and surprise; a metric M6 -1 threads into the hole "like it growed there" !!
Go figure eh ? ( that is some Canadian talk for you )
Thanks one and all again for your input. Knee grips are on and the bike looks great !
Grant
PS. Driving it every day to work in Toronto traffic is a trial by fire ...one up, three down...right ?
small-image-copy-jpg
I thought there might be a 6mm thread in there, it was unlikely they'd cut a cycle thread these days. Job done and looking goodsmiley
Rik, we'll carry on about tank thread sizes via e-mail to save people from out rivet countinglaugh
