Front fork
On rebound over a big bump the front suspension returns with a clang.
Could this be a) not enough oil in the fork legs
b) wrong oil or knackered oil.
c) something wrong with the rebound mech.
Over soft bumps the suspension id fine.
Any ideas
This is called 'topping out' and is generally the sound of the internal bushes bashing against each other. The general cause is worn fork internals. The worst wear probably being the damper rod parts. Possibly your fork springs could be too strong but this is unlikely.
I had these symptoms on a slimline. I changed the fork oil to 20 grade and put 200CC in each leg and is perfect now. Really made a big difference.
I'm going to experiment with a heavier Noirton next week. Again 200cc's in each leg but this time 30 grade oil.
Yes Dan, Mick Hemmings sold them. Basically, when you took your Norton off the centre stand the forks would dip at the slightest resistance. What that mod in the top of the stanchion did was to take up some of that slack.
But I found that 200CC of slightly thicker fork oil in each leg also did the trick and improved handling too.
