Hi Everyone,
hope you are well, I'm struggling to fit my new premier amal carbs
got some shorter inlet manifolds and the studs and allen bolts that are meant to be for them
also got the original inlet manifolds that were off the 376 carbs,
question is which set up is right
put some pictures up
option one
slim gasket, tufnol, slim gasket, tufnol, slim gaskets, manifold then carb
option 2
get some longer studs and use the original mono block inlet manifolds
option 3 cut the studs an the allen bolts down
then fit gasket, tufnol, gasket
help please haha confused and not much in the haynes manual or books
Thanks in advance,
Tom
1-jpg
If you look in the later e…
Tom.....your carb intake s…
Tom.....your carb intake spacers are too thin. You really need the 1" (25mm) size spacers to get the best performance out of these carbs. They will also fit on the studs better. I think the part number is 23872 but do check this out.
Previously tom_steele wrot…
Previously tom_steele wrote:
Hi Everyone,
tom..
you need to use the 1" spacers as phil suggested with a tufnal up against the head. thats the set up i have and with the standard studs should be ok.
tony.
option one
option 2
Thanks in advance,
Tom
Thanks everyone got the lo…
Thanks everyone got the longer manifolds to stick on that were original to the bike, the 1" ones, was given a bum steer on these thinner ones by a shop saying the longer ones would cause a misfire / flat spot,
found out last night that they are for an air cleaner being fitted,
the studs aren't the right length drat so going to get some ordered from andover later pretty sure I've seen the right ones,
Many Thanks,
Tom
Tom. The original inlet sp…
Tom. The original inlet spacers fitted with 376 monoblocs will have a smaller bore, 1 1/16", than the 930 concentrics which you are planning to fit. You will have a mis-match of parts, and will need to open them out to 30mm; 1 3/16". You will then need to remove the steel sleeves in the head, and blend the ports in to match.
I assume this has not already been done, as you have the 376 monoblocs at present. You may have been better off getting 26mm concentrics, or maybe 27mm with a little blending of the inlet spacers to suit. The bigger 30mm carbs may give you a few more revs at the top-end, whilst sacrificing mid-range.
Hello Tom - I had a late 6…
Hello Tom - I had a late 650SS (67/68) that had two concentrics fitted as new. It also had the shorter inlet manifolds with balance pipes and no air filter (optional fit). It also had the twin coil set-up with the capacitor in parallel with the battery. It ran very well without hesitation or misfires. It wasn't as quick as the early ones but it was or appeared smoother. I also had an Atlas from a similar year and it was similarly configured with concentrics. I seem to remember a story about the spray tubes and needles being different to other configurations. Phil may enlighten us ?? Cheers - safe riding, Howard
Howard. Bear in mind the l…
Howard. Bear in mind the later 650 to which you refer had a different head, different ports, different carbs, different carb spacers, different rocker geometry, etc from the earlier ones. It can lead to a classic mis-match of parts from different years not working as well as one may hope. Phil will remind us that he once fitted bigger carbs that made the bike slower.....
Hi lads thanks really appr…
Hi lads thanks really appreciate all this advice, for the reply mines about 20 bikes within the switch to Concentric, but was still mag and 376 amal's had all been running with a 389 single carb setup when I bought it
might have screwed up then oops bought the 930's a bit ago from Amal as the mono blocks were on back order,
have got all the inner sleeves still and original manifolds as the previous owner had owned her since new so kept everything bar the mudguards, had some nasty pattern ones on that was jamming the forks up
might just try them anyway and get some mono blocks on order, to go on it at some point, just want to get it running mainly as Im after doing manchester to cornwall on it leave the pesky german bike in the workshop haha
Tom
what do you guys reckon 1…
what do you guys reckon 1 " manifolds with no sleeve inserts when I had a look it was pretty much the same size as the opening on the carb, and same for the head, with the inner sleeves removed
what do we reckon everyone?
If you look in the later edition of the Norton Handbook the P106P there is a chapter on the Amal Concentric carburettor.
The choke size is 30mm and they used the Amal 930's
Main jet with air cleaner is 260, and with out air cleaner 280.
Pilot jet is 25cc, Throttle slide is a No 3, Needle jet is .107 and the needle position is Central notch in the slid.
If you look in the Master Parts List of 1966-1967-1967, on page 9 then it list all that you will need to know.
