1929 CS1 (CRICKET BAT)
I NEED HELP WITH MY BIKE ! THE VALVE DECOMPRESSOR LEVER ON THE CAM BOX IS MISSING ,MAKING IT VERY DIFFICULT TO START.
DOES ANY ONE HAVE HAVE A DRAWING FOR THIS PART OR BETTER STILL THE LEVER ETC TO SELL OR LOAN ME TO MAKE A NEW PART.
I LIVE IN HOPE ....DENNIS
May I make a suggestion until you get the de-compressor sorted. Put the bike in gear, rock the bike backwards against compression and try from there.Peter
Dennis
What diameter is the shaft ?
If it is 1/2" you may be able to use/rework a lever from an inter Norton or
the clutch release lever from a laydown gearbox (very similar)
These may be had from Paul Norman.
Arne
Previously arne_eftestol wrote:
Dennis
Arne
Hi Arne, Many thanks for your comments.
I cannot see a shaft that could be or has been used for the decompressor.
there is only a little mark on the rocker arm that indicates at some time pressure has been applied to crack the valve .
In a short while I will take a picture of the set -up and post again ,(a picture is worth a thousand words )Mean while many thanks for your comments
Regards Dennis
Regards Dennis
Regards Dennis
Hi DennisIf you don't already have a parts book and an instruction manual you can download them from here:http://www.vintagenorton.com/2005/11/pdf-collection.htmlThe parts book shows the items you need. The instruction manual does give a picture of how they fit in the section on removing the cylinder head.It seems to me that the shaft for mounting the decompressor lever will fit in the hole above the exhaust rocker where your cambox has a nut and bolt.If you search the vintage norton website there are some photos of CS1 and CJ engines whiich might help you visualise how the system goes together.Hopefully, if you can't buy the parts, there is enough information for you to measure up and make something that will work.Best of luckNick
Good Morning Nick, Many thanks for your info I will get on to it today.
Thanks again Dennis
Thanks again Dennis
Hi Nick, Further to my messarge this morning ,I have not been able to find the info from the vintage Norton PDF collection.
But your observation about the nut just above the exhaust rocker could well be the place to operate a small cam to depress the valve or something similar. Can you comfirm that the nut _shaft and the nut on the other sideis used for clamping only? if so a modified shaft with an extension would enable a cam or similar to operate .
Might I be a little cheecky and ask you to email to me a copy of a page that you might have that you think will help me. Thanks in advance
Dennis My email :-dennis.lawton@tiscali.co.uk
Dennis
It is now painfully obvious that my earlier comment about later cammy Nortons was way off.
I rally hope that you find a fellow owner who have one you can make a sketch from.
Good luck !
Arne
Dennis
Good luck !
Arne
Hi Nick, I have received your emails ....they are very helpful and I thank you most sincerly , you are a true gentleman.
If we ever meet I will buy the beer,Thanks Dennis
Hi Dennis,
Is this what you are looking for? This is the decompressor off my 1928 CS-1 engine. Let me know if you want to borrow it or I can see whether I can get a couple cast as I need another for a spare engine I have. (2nd attempt as the original file was 1,020kB)
regards, Ian
cs-1-valve-lifter-assembly-1-jpg
Hi Dennis,
regards, Ian
Hi Ian, That is exactly what I am looking for. Would some pictures of the
Queen tempt you to part with it ? or what is plan plan" B".
Either way I am pleased to hear from you ,Await your reply,
Regards Dennis
