I spent a couple of hours yesterday changing to original size main jet and fixing the front brake. Usual routine with chalk, file and emery tape. As it was pleasant weather, I took her out for a test run. The bike behaved well, but after some 25 miles it started to rain so I went home. Now to my questions. Is 45 to 50 MPH a normal cruising speed? Is 60 a normal top speed. Above 50 the vibrations are quite unpleasant. Only problem with her was that she blew all bulbs and the battery had changed to a football shape. Guess I'll make a conversation about that in the electrical section.
Mike, your bikes performan…
Which type of battery is (…
The battery was a tiny1.2…
The battery was a tiny1.2 Ah italian one inside a carved out Lucas. I did examine the MCR2 regulator and found a completely stuck field controlling relay. I think that a DVR-2 solid state regulator is a sensible purchase. Obviously the generator produced enough power to create some havoc. By the way, what type is the small bulb in the front lamp? Could it be a BA9s?
I would not say vibration…
The WD bikes have an 18 en…
Hi Mikael - I have some vi…
Mike, your bikes performance sounds about right and in line with mine, though I find 30-45 mph, anywhere in that range my ideal for cruising. Fastest I have been on mine is 55 mph, above that was blowing up speed!!! But all of that depends on gearing, many have a side car engine sprocket.
You certainly have an issue with your overcharging, that is for someone else but until then, it sounds like a new battery and bulbs + running with the lights on?
As for the gender of your bike, all of mine are male, strangely, with the exception of my 16H (female) but that is because it is a 'sod' or something to start when hot, down to me not investing in a mag overhaul.
