Another one I'm afraid. I've noticed that my bike is missing the centre stand arm part number 21165 . The one supplied by the NOC shop says it's the early type (along with the special nut). Will this one fit my bike? Currently my stand spring is attached to the footrest mounting stud so is largely ineffective.
This is....
Centre stand spring late gearbox types.
Hi Ian,
The early Electra parts list does indeed quote stand arm as 21165. Error.
Should be 24673.
The arm mounts, as you know, on the back lower engine/gearbox rhs mounting stud. On a special nut.
When the later gearbox was adopted for all Electra and later Nav/Jub the new gearbox internals needed the mounting stud above to be moved back and down.
The distance between stud and centre stand crossbar is less on later models.
So AMC had to change centre stand spring (24674 shorter and fatter), spring arm (shorter between centres and different shape), and the frame vertical section is different to suit the new engine/gearbox mounting stud positions.
On later gearbox types it is practically impossible to remove the lower rear mounting stud. AMC slotted the frame here so that the engine can be installed, removed with the stud in place. You need to back the nuts off at least 1/8 ins each side to remove engine.
These lightweights are tricky sometimes.
Tricky....
... is an understatement. The NOC shop doesn't show anything later than the 21165 and certainly not 24673.
Maybe I should throw myself on the generosity of this vital forum and see whether anyone has the later spring arm and nut lying about - although all this begs the question as to whether I can get it all to fit somehow....
By the way, received a bonded clutch plate from NOC this morning and fitted it - I am a bit dubious about whether full lift might allow a plain plate to pop out of the basket on full lift. I was pondering whether leaving a plain plate out (ie with 2 bonded plates back to back) might work.....
All this is a bit confusing to this simple soul who has spent decades with Commandos and singles.
Electra centre stand arm.
I have a copy of the original works dwg for this item specifically. I will try and load it on here later.
The drawing is to scale and shows dimensions. The arm should be relatively easy to replicate.
Admittedly some time ago when i last looked, but I'm sure the NOC shop had this part in stock at the time.
It's in the NOC shop
Just checked it's still in stock in the NOC shop. Ian, put 24673 in the search box and it should comer up.
That's fantastic Alan...
... just had a look and there it is!
Does it need a different securing nut to 21166E, which I assume is just a shouldered BSCy nut? It would be easy to make one of those especially if I have the arm to refer to.
Curiouser and curiouser.
That nut doesn't appear in the NOC shop. Interesting what you say about a structured part number. In my old days working as a systems analyst for Austin-Rover we avoided these as after a few years nobody remembered what the structure meant. And of course some (badly written) programs depended on them......
I can't get at it at the moment as the bike's up on a lift while I sort out the clutch and starter. Hopefully..... However it's probably worth getting the arm as I'll need it anyway.
Centre Stand Spring fitting..
For Ians information, there are two distinct versions of Spring, Spring 'C' shaped anchor, and retaining nut.
1) For all Jubilee & Navigator models up to engine number 106837:
Spring = 22408
'C' Anchor = 21165
Special Nut = 21166 - 1x required
2) For all Electra, and Jubilee/Navigator models from engine number 106838:
Spring = 24674
'C' Anchor = 24673
Special Nut = 24621 - 2x required
In addition - to fit the spring, it takes 2 people (one to hold the bike).
You do it with the stand retracted - hence someone needs to hold the bike.
In that way, there is least tension on the spring.
*You remove the stand axle that it pivots on.
*Assemble the spring to the 'C' shaped anchor (on the offside-right-of the bike).
*Connect the bottom of the spring to the stand crossbar.
*With the stand in its 'at rest' position, you should be able to re-insert the stand axle.
*Use NOC Specially modified Pivot Bush 22150 (2 off reqd) as well!
You don't need.....
You don't need a second person (any way the wife is doing the ironing!!) chuck the bike against the garage wall!
Only two people?
Took me three. The wife sat on the bike holding it up and brakes on, the boy pulling on the spring and me guiding the spring in to place.
Went together easily. Usually, with those two "helping" things can go wrong very quickly!
(Don't tell them I said that).
I've tried to get a photo....
... not very clear. Is the arrowed item the nut in question? How can this retain the anchor? It looks as though it's the wrong way round going by the sketch Peter kindly sent me.
Ah, yes - the good old head…
Ah, yes - the good old head scratcher! Although this is a Jubilee (later type) it's the same parts. I fitted two of the shouldered nuts to keep the curved arm in place (see photo if it helps?).
Bruce
Thanks Bruce,
... much clearer photo than mine and helps to see general layout. I was wondering about just using a plain nut outboard of the shouldered one although I can't see how much thread I have to play with.
Not Electra....
but Navigator. Noting what Peter H has just said, I moved the stand spring to the other side to avoid any possible entanglement with the oil pipes and speedo cable. The attached photo shows the up stop the same side. In this position it allowed the stand to touch the silencer. The stop is either deliberately cranked or distorted, either way, the stop now faces the other way. Hasn't stopped the stand clouting the silencer, the stop slowly moves, eventually allowing the stand to touch the silencer.
I'm presently modifying an RE back hub/brake to fit the bike so when the swinging arms off the bike I'll sort out the stop.
Stand stop.
Hi John,
See it you can find two 1/4 ins cei bolts to replace those two 6mm bolts fixing the stand stop arm. This will stop the arm being pushed up so far by the stand until stand hits silencer.
The original 1/4 AMC bolts had about 3mm plain shank under the head to make a best fit in the 1/4 ins stop arm and frame section holes. Hard to find these bolts now. The bolts also secured a spray guard at the bottom of the vertical channel, but being some sort of card composite, most have long gone.
My stand still clunks embarrassingly against silencer if I let the spring do it's best. Keep a restraining foot on the stand and silence is assured.
Peter, slightly off topic…
Peter, slightly off topic but I made that "splash" guard out of plastic - you can see it in the photos, luckily I still had the original cardboard one (albeit very "old") as a pattern
Worth a thought....
...John, although access on that side is very tight. I'm not sure but I don't think I have the stop either although that's probably a minor consideration. Looking at photos I could probably shift the speedo cable outside the frame tube or even reroute it entirely so it leaves the drive gearbox near vertical.
Plenty to keep me occupied.
This is the centre stand spring mounting 'gubbins' as fitted to my 1964 Electra.
Not had a problem on my machine in 40 yrs on/off stand!
I have heard 'on hear' that the stand spring is a B***steward to fit-take care.
