Ashley Cutler, our friend from Andover Norton, has opined in several posts on this forum to the effect that that "850 will rev out about 1K rpm less than a 750 unless it has a large valve job"; most recently: https://www.nortonownersclub.org/forum/pistons-2 .
Where does this assertion come from Ashley? Something you know from personal experience, something someone once told you?
For context, let's consider that 750s and 850s have the same stroke, conrods, valve gear, camshaft, 32mm inlets, The pistons weigh about the same. The 850 has a bigger bore which moves it closer to "square". The larger bore means that flow past the valves is less impeded by the cylinder wall. I would argue that 850s, with standard valves, breath better than 750s.
The 850 develops more torque lower down the rev range which allowed it to be overgeared to reduce engine speed in normal use and improve reliability. But this has nothing to do with whether an 850 will rev if allowed to.
And what revs are we talking about? Redline is at 7000. 850s will certainly do that. Are you reving your bikes to 8000? More? As an aside I'd note that the original Hepolites in 750s had a slotted oil grooves and the piston top was prone to detaching itself at high revs.
So where, Ashley, do you believe the 'inability' of an 850, with standard valves, to rev and breath comes from? I look forward to being enlightened.
Oooooh! I love it when a…
850 revs out fine
I was fortunate to attend the 2011 Bikers Classic meet at Spa in 2011 with Norman Lorton and some tasty Manxes. Luckily for me I was riding in a different class so never crossed tyres in anger against these swift old war horses in the 140miles or so around the track that weekend.
However my modified Mk3s engine performance surprised me. Basically blue printed standard spec with DIY lightly modded RH4 head, lightened rockers, titanium valve spring retainers, Maney steel pushrods, +0.040" JE forged flat top pistons and Carrillo conrods. Valves were standard size Black Diamond with stock AN springs.
Compression was a measured 8.5:1, carbs were 32mm Premiers with long Amal velocity stacks and a custom K&N filter, the only real aftermarket tuning part being a USA Johnson J380 cam.
Essentially a smoother modern version of the PW3 enabling 0.006" and 0.008" valve clearances rather than the usual 0.011"
The crank was balanced by Bassett Down to offset the heavier Carrillos. Most of these mods were for efficiency and reliability rather than outright power.
I initially kept the revs at 7000rpm but soon noticed it revved easily to 7600 on one delayed shift. Mindful of the fact I was halfway through a 1000 mile return ride fully loaded with panniers, tent and leathers I resolved to stay at 7000.
However on a later lap in the company of a Guzzi 850 cafe racer, a quick glance at the Eliot electronic tach showed 8000rpm with no signs of distress from the engine. I had forgotten to change gear and was still in third on a 100mph sweeper.
I too wait to hear how well similarly modded 9000rpm 750s have gone on such a trip, but not expecting tales of creamy 850 torque everywhere not just low down...
The Red Line
When I bought my Mk3 (forty or more years ago), it had a Smiths speedo and a Vaguelia tacho. I found a T160Trident "NVT" wavy line tacho and had it rebuilt into a Commando studded case...What I hadn't realised was that the Trident didn't have a marked red line and I wanged around for about ten years with the idea in my head that the Commando red line was at 7500...I regularly revved the 850 to 7 1/2 through the gears in those days...it stayed together.
I have pretty well always run with reverse cones and the non-A suffix (750 type) air box.
I've heard that the short stroke 750 wasn't popular as it called for more gear changing.
Revs
I got some good advice from Steve Maney when building my engine. He also remarked that 750 and 850s had no trouble revving but didn't necessarily make big hp as a result. Solution for best power and efficiency was to get the fuelling correct for these revs. True for both road or race.
Hogslayers John Gregory and TC Christensen solved this conundrum in true hotrod fashion by adapting automotive Hilborn fuel injection to pour plenty of juice into the fire. End result around 150hp per engine and good reliability without mega high rpm.
Never done a classic track day?
Never done a classic track day Peter? When a Jota comes past you on the back straight at Mallory, you`ve just got to get past the flash B@stard again, which I did, diving under him going into the bend at the end of the straight on the lighter Commando. He never bothered me again. Commandos are quite capable of surprising people on a track. It was showing 90 on the clock at 7000 rpm in 3rd coming up to Gerrards and still wanting more, only my pants wouldn`t take it : ) Standard 850 engine with clip ons and rearsets.
Not a question I would have…
Not a question I would have expected to find on a motorcycle club forum Peter :) . Especially for a marque that makes much of its sporting heritage. But it's a question you'll have to direct to the people to whom Ashley has responded that an 850 won't rev unless larger inlet vales are fitted.
Slow Riders
It's not just the fast chaps on trackdays who need to red-line...Those of us who are slow-in and slow-out on bends need to thrash like b*gg*ry to keep up too.
If your group of friends steadfastly maintains a policy of "last one to the pub get's the round in", this is a matter of some importance.
Rush to the redline
Anywhere in a Commandos power band from idle to redline or beyond is fair game. It was a Superbike in its day, feared throughout the land and I recall most being ridden that way.
A possible source of the revvin' 750s old wives tale was that they were lower geared than 850s as far as I know. An 850 with a similar 19t front sprocket and more torque should comfortably outgun a 750 with both in standard tune.
However I won't be stripping down my primary drive to find out, 850 21t front sprocket the best all round gearing for me to avoid buying the beers.
It is my road bike
It is my road bike Peter, 50 something K on the odometer, never had to look at the bottom end, still going strong. Something owners of the new Nortons can only dream of, apparently . . .
Apparently
Not quite true Alan , Yuichi Yamamoto in Japan has 53K on his 961. Apparently some people seem to biassed against the 961, not me having owned them since 2015. I still remember the problems with my Fastback, Interstate Combat motor and the 850 interstate in the sixties and seventies but there wasn't any internet then so they didn't get a slagging off like the 961 and being a Norton man it didn't put me off buying a modern one.
Oh Richard I still maintain there is no reason to red line an old bike, simply because I have too much mechanical sympathy to do that. Maybe try going in slow and coming out faster to save the poor old donk, and your bank balance. :-)
That's great news Peter
That's great news Peter, perhaps a pole of 961 members could be conducted to see what percentage are actually perfectly happy with their bike's reliability and we might see them in a whole new light rather than the recent bad press.
Original Commandos did of course have issues back in the day also well reported in the press at the time but they all seem to of got sorted eventually, perhaps dedicated owners will do likewise with the new bikes. I wonder if anyone revs them to the redline?
The answer is simple, stick…
The answer is simple, stick your bike on a dyno and you'll find out, just like I have and my opposite number has done with his 750. The result I had I queried with Steve Maney and he found the same with the 850. The best way to move the roll point higher up the rev range is to use big valves so the 850 can breath more efficiently, the size of the standard valve has spare capacity for the swept volume in a 750, but is just beyond capacity for the 850.
I have the traces of the 750 and 850 overlaid, and it proves exactly what Neill was told by Steve Maney, both hit max HP (not the same HP) at around the same time, and carry on revving, but the 750 holds the line longer
Dyno runs are pretty cheap and can tell so much, fuelling response, air fuel ratio, torque and HP. I don't get why more don't do them - you don't need to rev to max if you don't want to.
As some above have said, its about where the power is useable, some may have noticed the 920 going to auction at the end of the month, it is a bike that AN acquired, we repaired it and tested it in our car park, and it even wheel spins freely in 2nd gear.
So Ashley, let me try to…
So Ashley, let me try to interpret what you're saying, and do correct me if I've mis-understood.
A standard 850 (828) Commando engine, as delivered by the factory, so 8.5:1 compression, standard camshaft, 32mm carbs, airbox & filter (pre-Mk2A/Mk3), will reach peak power below the 7,000 rpm redline. Whereas a similarly standard 750 (long-stroke) reaches peak power at somewhere closer to 7,000 rpm. Further, the evidence you've seen shows the 850 peak is some 1,000 rpm below the 750.
And Steve Maney contends that the 850 is more constrained by the size of its inlet valves than a 750. Therefore an 850 can benefit from larger inlet valves, breathing more freely and producing more power further up the rev range. Maney sells big valve conversions doesn't he ;)
I won't disagree with Steve Maney on this point: a big valve head on a properly prepared race spec. engine is likely to make more power than one with standard valves and, maybe, continue to make power higher in the rev range. But whether bigger valves benefit a standard 850 or whether standard valves limit a standard 850 is highly debatable. And I say that because I don't believe there's any data from someone fitting bigger valves to an 850 but leaving it otherwise standard.
But none of this adds up to your blanket assertion that "850s don't rev". The experiences described here by 850 Commando owners, and my personal knowledge of how hard an 850 engine with standard valves can rev, argues strongly that the opposite is true.
Do give Steve my regards next time you're chatting.
Stan, Para A - yes. Para B -…
Stan,
Para A - yes.
Para B - yes, and yes he did and so did others, and like the many that pester me every week that they want cylinder heads with more material to re-angle and allow larger valves to be fitted along with porting work. Just like those currently working on 8v heads - why? because they know the bikes need to breath better, once the bike breaths better and revs higher they more area under the curves to work with.
Para C - Possibly, as I doubt if anyone has done that and dyno'd the bike afterwards to achieve a result.
Para D - it's not an insertion - fact, take a 750 and 850 and put them on a dyno and you will see it as you'll soon work out where the revs will roll off. You'll get to point where the energy incoming will only spin the crank to a certain rpm limit, the rotating mass now in play, either lighten the crank, rods and pistons or get more energy into the cylinder.
I will mention you to Steve next time our paths cross, as he said and others know, you can tune a 750 relatively cheaply and easily, to tune a 850, needs more work to get the same comparable increase. We have had several 920's here, and one of those 1007cc bikes, none were quicker than my sensibly set up 850 that runs with FA head, PW4 cam that many said would not work and standard unbalanced pipes and peashooters. However, the latest 920 we have and going to auction is far quicker, but we have not had the engine apart to see why.
For a good morning out take a friend with a comparable 750 or 850 to a dyno and try it, the results are worth obtaining, and it is good fun, checking to see how quick your carbs meter when changing gear, fuel / air ratio etc.
Big Inlets OK
I think it's obvious the myth of 850 non revability is simply a red herring as I and others have found so nothing further to add there.
The standard size valves work perfectly in different ways on 750s or 850s. I never believed the 750 was inherently better, but the lower gearing and slightly peakier delivery undoubtedly convinced people otherwise. No denying the 850 torque however and it isn't more expensive to get good power than a 750, many of the same parts are used or similar cost. I favoured the 850 as a better place to start tuning.
Steve Maneys and Paul Dunstalls race bikes operated at a far higher level than our road bikes. However there are things both did which can be of benefit to keen DIY enthusiasts interested in real improvements to everyday bikes 750 or 850, like reliability and efficiency.
Using dyno tests between a 750 and 850 to back the revability debate is also a non starter, it simply compares the results, not how quick each revs. In fact going by your published dyno results I have before me, both bikes peak power is the same 6000rpm±. Both should also reach the 7000 redline so no way is the 850 1000rpm lower. Depending on what the operator feels is adequate, most end the test just past the power band unless you specifically ask them to hit the redline.
The PW4 cam you use is almost certainly unsuitable as others have stated and a standard cam would be a much better option. I followed your posts on Access and apparently it took some work to get it installed and working. However the dyno result was no better than the 64.5k mile, standard 750 tested beside it. Not what I would expect from a healthy 850 having a Fullauto head with optimised porting, an experimental cam and free flowing exhaust.
Re bigger valves:
I bought a late production Aussie Fullauto head, a dream come true when my RH4 died. I fitted +1.5mm Black Diamond inlet valves to the existing valve train and a standard type Web#312 cam after the excellent J380 was damaged by cam follower disintegration. So along with the mods listed in my first post, this engine is really a blueprinted standard spec 850 carefully assembled and tuned with a big bore exhaust and Peashooters. Ignition is Trispark Classic and 3Ω Dyna mini coil set to 28° Cam fitted to standard marks, no degree wheel required as advised by Jim Comstock who sold me the cam
My goal was to improve low to mid range with more top end and better fuel consumption than the 45-47mpg I was getting. No intention of revving it any higher to achieve this as those AN customers seem intent on doing. After many jetting adjustments on an (unable to be revealed) long stretch of good tarmac, my seat of the pants dyno had the bike revving to 7000rpm in all 5 gears and getting consistent 60-65mpg on long rides. The main jets felt slightly weak but I'd mislaid the richer 270s so dyno test was with 260s.
Time for a dyno run at Dyno Tech Basingstoke, on the now 13,000 mile since rebuild engine to confirm my efforts. Result was a nice curve from 3000 to max power of 55 rear wheel hp at 6300rpm (with flashes to 57-58hp) The torque was even better with a 50- 52lb ft flat line from 3000 to 5800rpm or 50 to 100mph, exactly where a road bike needs it.
The operator was amazed and overlaid the result over other Commando runs he'd done, including Ashley's 850 and 750 plus a couple of Dunstallised Commandos. None came close, notably on the torque curve. I remarked it doesn't feel that powerful on the road just open the throttle and it goes. He said it does that because of the progressive power and torque, no power band as such.
He said fit the 270 mains to smooth up the weak top end and walk away. I eventually found the 270s and fitted them, can feel the difference and still getting 64-65mpg on long trips at the current 27k miles.
No debate in my eyes that bigger inlets properly done on an 850 benefits the whole range of power and torque not just at high revs. How a pure standard bike with properly set up larger inlet valves would work is debatable until someone does it. I suspect it would make a noticeable difference. Over to you Ashley and Stan.
Burn up showdown?
Can we organise a burn up showdown? Anyone got a drag strip to spare? : )
Peashooter benefits
All above very interesting ( what is a "Fullauto" head). My 850 mk2a when dragged out from under the bench was serviced and ran well enough. I fitted peashooters of better finish and removed the air box in favour of trumpets. I was amazed how free the motor ran and the torque was present right through the rev range. It was very under geared for this arrangement so I upped the output gear to a 22. Slightly long for town use but I don't do that often. A big difference to the standard set up.
J
Fullauto cylinder head
Made in Aussie with revised porting input by Jim Comstock. D shaped exhaust ports the most obvious (and effective) feature. Modified inlet ports and combustion chambers were CNC machined on the later heads and perfectly matched.
The guy Ken who did it got plenty of criticism, mostly the usual unfair rants by people who could never achieve this themselves, but not helped by his abrasive personality.
He had a puzzling mismatch of parts to partner his own Fullauto. PW3 cam and a single Mikuni resulting in the worst Commando dyno chart I ever saw.
He was 100% convinced it was the Worlds Best on the road and if he was happy, that's OK by me.
Pics below are of mine with the modified bits and bigger inlets fitted.
I found the head a superb piece of engineering given the intricacies of the part and glad he'd managed to produce them at the right time for me. Now retooled and made in the USA
I'm convinced Amals run best with trumpets, especially the long cast/billet ones, not surprised your 850 went well with these and Peashooters.
Thank you Neill
Yes a beautiful casting and nicely machined. Is that an offset hemi combustion chamber? I use a weir disk in my single cylinder exhaust to stop back pressure affecting the fill. It's not used in anger so no comparative runs to verify its effect. I did a quick search on our forum and found a few interesting postings on the Fullauto. To see the head ready for installation shows the differences and by your account the tangiable benefit. Thanks again.
Hemi
Hi Jon
No just a normal hemi but squish is offset due to progressive over boring from 500cc I think. Someone here will know the full story. Resulted in what they call a desaxe layout
https://www.nortonownersclub.org/forum/desaxe-engine
A recent Access post had a guy making stainless 3D printed inserts for Commando RH4 exhaust ports to try and duplicate the Fullauto effect. Similar to your disc but filling in the port floor as well. Looked promising with both 3D exhaust and inlet inserts now available from Jim Schmidt Motorsports.
Cammy Desaxe
A friend and I have discovered that some prewar cammy Nortons were built Desaxe. Joe Craig referred to it after the war but it was discovered on 1936 / 37 single cam 500 and 600 motors.
thanks for the info.
Nice to see Neill's bike…
Nice to see Neill's bike doing well and thanks for putting it on the dyno, I assume it was running near weak on the Dyno as per advice for the jets, if he'd looked at the fuelling from my graph I was nearly borderline beyond too rich, that has now been corrected. What head was used? the RH4 or the FA with +1.5mm inlet valves. The comparison to 750 is somewhat of a misnomer. The 750 we tested was bog standard, no balanced crank, no FA head, no PW3 cam, no large inlets, etc - says a lot for the 750. If anyone has an original MK2A /MK3 with black caps and original polydyne cam and the venturis fitted then it would be interesting to dyno that - that is what the baseline was back in the day. I predict an early 850 with RH10 head would fare a little better than a later 850. Sadly bikes in original spec are few and far between.
FA heads - do not make the mistake they are all the same, from what we can gather the STS version does not have the earlier FA inlet ports (mine has the early unfinished inlet ports) but has the same exhaust ports. There are other differences but for us in the UK it would not make much difference. All are made from the incorrect aluminium.
In defence of Ken (a rare occasion), he made replacement heads, not race heads, using sensible updates where they could be incorporated. Down under I suspect he wanted a bike that was comfortable and reliable for the distance, not performance.
Strange about the PW4 cam versus standard, Norton went back the 06.1084 cam, and with this cam the bike I was able to get the rear wheel to break traction when over taking. I still advise that the two best cams out there are the 06.1084 or the PW3 (changed by PW just before he passed away to correct some errors). The PW4 makes the bike ride nice, but I suspect would benefit from Neil's larger valves, The hassle to fit the PW4 in a road bike makes it a non viable option
So more has been established, but until someone puts a standard M2A / MK3 on a dyno then I still stand by my comment as no one has dyno'd a factory standard 850. Larger inlet's make a difference as suggested and now proven and seems to be the best cost v gain mod to use. Anyone else for the dyno? it's good way to spend some hours as Neill would no doubt agree.
Maybe a section in Technical where we could post the graphs and the bike specs for all to see would be nice.
Some interesting info there…
Some interesting info there Ashley, I agree the stock 06-1084 cam and also the Web #312 modern equivalent are the best all round for street 750 & 850s. Flat top pistons, no valve cutouts required, set to standard timing marks and 006"/008" valve clearances.
Regarding fuelling, my bike runs best on a slightly rich 12:1 air fuel ratio same as my air cooled Yamaha. Tuned to what the engine wants, not to a figure.
750s had relatively larger valves compared to bore size plus higher compression, different heads and lower gearing than the 850 which would explain the different feel of the bikes.
Inlet valve/bore ratios:
750 52.20% 38.1mm inlets 73mm bore 745cc
850 49.48% 38.1mm inlets 77mm bore 828cc
My 850 50.77% 39.6mm inlets 78mm bore 850cc (+1.5mm inlets +0.040"bore)
The standard 850 would need 40.25mm +2.15mm inlets to match the valve/bore ratio of the 750 possibly needing the valves re angled, not a home DIY fix. Mick Hemings big valve conversion may have been something like this. Knew exactly what he was doing!
Kawasaki guru Larry Cavanaugh (RIP) referring to the Z1 903cc and Z1000 1015cc fours gave the information above relating to those engines but I adapted it to our Nortons.
He also advised that hemi combustion chambers like 51% of valve/bore size minimum for best performance.
My Mk3 compression ratio on it's original pistons and RH4 head measured 7.7:1 compared to the 750 8.9:1. Now with +0.040" oversize pistons and light cylinder skim for zero deck height, it's still only 8.5:1 but this gives perfect valve geometry with standard length steel (Maney) pushrods so no plans to skim the head.
A dyno database relating to NOC bikes would be a good idea and reference. Outright figures not that important but the power and torque curves are informative.
Inlet valves supplied by…
Inlet valves supplied by Mick Hemmings for his 850 big valve conversion are 40.5mm diameter. It has been suggested that these are BSA valves.
I let Mick talk me into doing the big valve/fully sphered head conversion and, on an already tuned motor and after we'd got the compression ratio back, it was impressively quick - for 4 miles. The inlet and exhaust valves were just 'kissing', peening over the edge of the exhaust valve so it didn't seat. So I chucked that head in the corner where it languishes to this day.
To Ashley's comment: "Larger inlet's make a difference as suggested and now proven and seems to be the best cost v gain mod to use.".
Yes, bigger valves can make a quick engine quicker. But there are potential downsides and it would not be my first tuning step and definitely not my only tuning step. I suggest you do what it says in the 850 tuning sheet (Service Release N3/56 June 1973) first which has a proven track record.
And, on the subject of 750 versus 850, I would note that the shrouding effect of the cylinder wall is less with the 850's bigger bore. And therefore an 850 should breath more easily with the same size valves.
Valves and Tuning notes
I agree with Ashley's comment plus my own and Micks results. Increasing inlet valve size by 1.5mm was stated as one of the most effective single mods for the Commando engine to improve power throughout the power band by Jim Comstock, another being higher compression. This influenced my decision although it requires very careful setup.
You've overlooked a feature of the Commando/Twin and all two valve hemi head designs however. They largely eliminate shrouding by setting the valves at an angle, moving away from the cylinder walls as they open and allow a spark plug closer to optimal centre.
Easily visualised if you look at my earlier pic of the Fullauto head but you may be right in saying the overbore favours the 850.
An expensive cylinder head thrown to one side because the valves clash after a 4 mile run?? Embrace the classic can-do Hot Rod mentality Stan "you got a problem, deal with it"
Clearly a basic fitting or mismatch error and this potential problem is mentioned in the 850 tuning sheet N3/56 now N3/73.
This has some excellent info, strongly biased toward racing with the cylinder head porting mods probably superseded by other developments during the same period and later. Jim Schmidt has some excellent porting info on his JS Norton website.
The N3/73 ignition timing of 30/31° wasn't used by Paul Dunstall, he stipulated 28° which points to a more efficient combustion and which also works best on my e start Mk3 with Trispark.
The interesting comparison…
The interesting comparison is not just restricted to 750 versus 850. I presently have an 850 Mk1 and an 850 Mk3. Both in Interstate form, standard condition with newish carbs and recently reconditioned heads. They both have the original air filter arrangements and gearing as far as i am aware.The Mk3 has a PW3 cam and the Mk1 the standard Norton cam.
I cannot speak for top performance and the bikes have not been dyno'd, but the the Mk1 is noticeably more revvy and seems to accelerate a lot more sharply.
Alan that sounds about right, original Mk3 state of tune not the best for a PW3 to run well!
My Mk3 with original gearing, airbox, carbs and black cap silencers had a Combat cam fitted when I bought it.
Riding the bike home from Preston I opened the throttle at 70mph on the M1. It made a louder exhaust tone then very very slowly picked up speed. Luckily this cam and followers eventually died and I replaced them.
Better keeping the stock cam, fitting a separate K&N air filter, Peashooters and resetting to the earlier 850 jetting if you want a more lively response.
Check out posts #15 to #18 here:
https://www.accessnorton.com/NortonCommando/comstock-valve-springs-and-cam-wear.25772/
This is now taking it back…
This is now taking it back to the original post. Keeping it simple, you need to efficiently fill the swept volume with the correct A/F mixture. That volume then needs to combust as efficiently as possible at the correct time to spin the crank. Heavier crank and pistons needs more energy, but the 850 has a larger volume therefore more energy - looks like it is not a problem, however you need to get this perfect mixture and volume past the inlet valve every cycle. Using the same cam in both a 750 and 850 the valve will open the same distance and open and close at the same time during the cycle. Speed this up and you are trying fill the volume in a quicker time period. The 750 will fill more efficiently at the higher speed than the 850 and thus sustain itself longer allowing the revs to rise further. The 850 is approaching a condition where the valve is hindering the volume being drawn into the cylinder.
Starting from this point what can be done. Open the valve further, yes, but a cam with large lobes will sap power - fact, as energy is needed to compress the springs further, solution lower the spring rate or start from longer fitted length position. I discussed this larger valve lobe issue with Dave Newman many years ago. With this is the risk of losing valve control over the lobe, depending on the cam and tappets it could prove fatal pretty quickly as impact on the cam can cause work hardening and granulation, if your cam and tappets can handle the impact then but it can give a small boost when this happens with little risk of damage. Open the valve longer, yes, but needs to then have tuned exhausts and inlet tracts.
Lighter crank and pistons - less weight to spin, but sacrifice the ability to tick over in worst case.
Better carburation, but the trick is getting the carb and inlet tract to work in the range the cam will work best.
Port design / longer carb intakes, useful but again needs to be matched with other improvements.
Larger valves, yes but the Norton engine is limited in what can be fitted, not only that there is a limit on just how larger the should be before it cause detriment to the performance. As Stan says there are a good few things that can be looked at first as above, but the larger valves is definitely a good move.
Norton knew larger valves were needed on the twin - they actually did themselves in the 50's on the early twin. Would they have done it on the 850, I suspect so but by that time they ran out money and the design envelope was pretty restricted as it was by the time the 850 arrived. Did they know the 850 suffered - yes, and was most probably the reason the 06.1084 cam was reintroduced in mid 1974, I bleieve there is service release stating this, though not if it was a public release or dealer release.
Ahh, Beehive springs, this…
Ahh, Beehive springs, this is something we have looked at and yes, we could get them tomorrow. If I was racing and wanted as light as possible I would use them but for road use I would not. The gain does outweigh the risk of a spring failure - rare, but potentially very messy if it does.
Oooooh! I love it when a Frank Thomas gauntlet gets thrown into the ring.
Over to you Ashley.
