Dear all, I would appreciate some guidance with this one.
It's not very easy to see from the attached photo but I can't turn the welded adjuster nut because it fouls the big axle washer.
The adjusters are after market stainless steel items.
I would have thought that with everything slackened off I should be able to fine tune the chain tension in the normal straightforward way.
Thanks Roger
Get a couple of reduced hex…
Simple plan
Turn the o.d. of the washer to just clear the hexagon on the adjuster. Not much would need to be removed looking at the photo.
Either the wheel spindle nut…
Either the wheel spindle nut reduced section diameter is too small or the end stop on the adjuster bolt is to short.
Have you though of chamfering the edge of the adjuster bolt hex that's catching the washer?
Change the adjusters
I'm sure the originals had a reduced size hex to overcome this issue - featherbed ones certainly did. Surely one of the various parts suppliers has them with the correct thread for a Commando?
Regards,
George
Lateral Thinking
How about a 0.10" smaller diameter washer under the head of the axle. That should give the adjuster hex nut enough clearance all round.
The original...
The original adjuster bolt had a 1/8 Whit head. Nasty fiddly thing. Any improvement in this area must be worthwhile. (Royal Enfield snail cams come to mind)
Alan; Would you have a…
Alan; Would you have a pattern for the R.E. snail cams? Thank you. Mark
Featherbed and Commando different
Featherbed frames used reduced head adjusters but Commando doesn't. The head should be 1/2 inch AF. Either take some metal off the washer or off the edge of adjuster hex nearest spindle.
Aftermarket junk
On my 1974 850 MK2 the chain adjuster head size is 7/16" and the lock nut 1/2" spanner fit.
This is as fitted by the factory and correct as I've owned the bike since new.
You have aftermarket junk, send them back for a refund.
sorted
Those are the correct chain adjusters you need, 7/16" spanner size on the adjuster head, designed to clear the axle washer.
Sorted.
https://andover-norton.co.uk/en/shop-details-2/15347/rear-wheel-adjuster
Here are some numbers from…
Here are some numbers from original parts on a 1974 850 Mk2a:
- Diameter of spindle at adjuster: 0.86"
- Diameter of spindle washer: 1.125"
- Height of adjuster bolt beyond hex 'nut' towards spindle: 0.15"
- Adjuster hex size: 1/2" AF
The clearance between adjuster and spindle washer is small but sufficient to slide a piece of paper thru - using the numbers above you will get 17 thou.
From your picture, it looks like the spindle has been reduced too far. You could modify the adjuster by turning (as in - in a lathe) the hex 'nut' back to give you the clearance you need.
Feked sells snail cams….
Chain adusters
Thanks for all your input/comments/measurements for what was yet another irritating (albeit minor) thing wrong with my bike that looked pretty when I bought it but turned out to be full of problems. The only non-stainless part (ie. what I thought must be original) where the large axle washers - see attached. Back to new standard ones from AN and all is well and working as intended.
Thanks again Roger
Level
I found with my Mk.III Commando that when the adjusters were equally level in terms of amount of thread left on each bolt, although the wheel was central in the swinging arm, it was not in line in with he front wheel. It needed to be offset in the swinging arm for it to align correctly. When parked, a number of knowledgeable enthusiasts advised me that the adjusters were not level. When the adjusters were level the rear disc became warm and sometimes quite hot because of the mis-alignment; it now runs cool and correctly.
Thanks Peter, mine look ok…
Thanks Peter, mine look ok but again I'll use a straight edge for the final check. R
Chain adjusters
Thanks Colin. I'd better assume nothing and check with a straight edge.
R
Get a couple of reduced hex nuts.
