Hi all where can I pick up the oil pressure light switch banjo and adaptor.
NOC magazine
Oil pressure switch
Hi Steve
That's the one I want,let me know when you have one for sale.
Roy.
Or was it somebody else? - See Roadholder 415 page 22
Oil Pressure Switch
LINK BELOW
https://www.nortonownersclub.org/html/archive/rh/415/22/index.html
ME!
Caution needed
I've used these oil pressure switches on several bikes over the years. A great idea to use them.
A word of caution, the smaller ones use one of three different sizes of thread.
1/8" BSP 28TPI, 1/8" NPT 27 TPI, M10 x 1 25.4 TPI.
Visually they look to be the same, measuring the outside diameter might not be conclusive in separating the imperial from the metric. Check with a thread gauge. The heavy handed will get the BSP and NPT to screw together..........
another option
Don Pender also sells a take off electrical sensor ( from timing cover outlet to rockers ) which triggers an indicator light for low pressure warning. $30.
DIY option
Wasn’t someone offering a system some months ago?
