Vavle stem seals 750 commando
Anyone suggest a decent stem seal that doesn't go hard in a couple of years please.
bEST  JIM SMITH VITON SEALS. a PART OF MANY OTHER INFO AND RACING STUFF
THE SEAL IS JUST AN FIT TO ORIGINAL INLET VALVE GUIDeS
jsmotorsport.com/product/viton-valve-guides-seals/
RGM also do Viton stem seals : https://www.rgmnorton.co.uk/buy/valve-stem-oil-seal_74.htm .
Having only ever used Norton ones, I can't comment on whether any of these are any longer lasting. I don't know what the original seal material was, or what Andover are selling today (although, reading between the lines of Roger's comment, they might be British Leyland parts). Viton is certainly preferable to the common butyl rubber but it's probably a bit hot around the valves for either of these to be especially durable. Teflon would be best but I don't know of any in that material.
