Hi i'm renewing by big end shells while i have the engine stripped down and a 1/2 socket is ti small but the 9/16 socket is to big could anyone tell me what size the socket should be for the nut to remove the big end shells on an 850 commando and where to get one?
Isn't it....
850 big end socket
michael,
its a whitworth socket you need,and may have to grind the end slightly so as to get a good fit on the nut,
From RGM website
3/8" BIG END (CONROD) NUT 3/8" BSC
Part No 067827
CONROD LOCK NUT (3/8") FITS ALL NORTON TWINS 650 AND UP. (SEE 17827 FOR SMALLER ENGINES). USE WITH BOLT 066486 (SUPPLIED SEPARATELY).
So yes, it would be a WW/BSF size
Don't forget to avoid 1/2"…
Don't forget to avoid 1/2" square drive! OK for car wheel nuts...not for motorcycles...
You'll need the 1/4 ww…
You'll need the 1/4 ww socket for re fitting the cylinder head as well.
.... a Whitworth spanner size?
