Model 18 Cam Follower Profile
My 1931 Model 18 has worn cam followers. These are the radius type and the wear is causing the valve open duration to be extended due to the change in position of the cam to follower contact point. I have sent the cams and followers to Newman Cams for reprofiling. Ken Newman has asked me if I can supply a drawing of the follower, or a good example so that he can recreate the correct radius. Does anyone have information on the follower profile, or a good example follower that Newman could copy?
Many thanks, Ian McD
Cam Followers
Know nothing about the shape but there are a pair on Ebay listed as title above.   Maybe good for  comparison/ experimentation...
Thanks Jon for highlighting those, I hadn't spotted them. They are not an exact match for mine, not shown on my photo is a socket on the upper face which locates the end of the pushrod. Would have been good if the seller had shown a side view to compare the profiles, but I could request that.
I am fairly sure that no-one on the Forum is going to come up with a Norton factory drawing of the cam profile - rocking horse poo would be easier to find. I wonder though if photos, or better still, a tracing of the profile of a good follower might be sufficient for Newman to refurbish mine with a fair degree of confidence. I would understand if someone was reluctant to let an original good spare out of their sight. Just for curiosity I wired a strip of 0.008" shim steel over the worn area of the exhaust follower. It stayed in place long enough to confirm that the valve timing then came very close to the expected values.
Cheers, Ian McD
Does the wear point correspond with the maximum lift of the cam? As it’s only the follower I would have thought a constant radius would be the original.  Can you not mirror from the non worn side?
I would have thought if you know the lift and the angle you can set the motor at that point of rotation open the valve the required amount then measure the  gap.  Take away the cold set clearance  and you know how much to build up to….
Someone will have one im sure….
I think when everything is new the contact between cam and follower is a line, with the cam always touching the follower at the same point. As wear takes place the line slowly gets wider, with the initial contact point moving towards the follower pivot. This advances the valve open point, while the width of the worn area maintains contact with the cam longer and delays the closing. I think your suggestion of trying to mirror the existing unworn radius will be the most practical approach. My test with the shim gives a fair indication of how much material needs to be added. I had hoped that Newman's past experience would have given them a good feel for how to proceed. Probably just being cautious, a known template being better than an educated guess. With hindsight I could have made up a template with my own approximation of finished profile before sending them away.
A couple of pages from 'Tuning for Speed' on cam follower profiles.  Also warning that case hardening might be desirable.
Note he points out that changing from flat to curved followers doesn't change timing (because lift starts at the same place when the cam lift point reaches top dead centre).
…To a good friend with a model 18.
He measured his at 13/32” radius.  He felt yours were not in bad condition and should only be dressed in and re case hardened.
 Hope that helps.
Thanks Jon but maybe I should say why I have sent the cam followers for refurbishment.
I am trying to resolve a valve timing anomaly which may or may not be responsible for reduced power from the Model 18. The open durations of both valves are longer than they should be, by approx 30 degrees for the exhaust, 20 degrees for the inlet. Thinking there was something odd about the cams I swapped them for another set. It made little or no difference to the timing figures. In "Tuning for Speed" Chapter 11 Phil Irving describes how wear on radiused cam followers can extend the valve open duration (as described in an earlier post). As an experiment I wired a strip of .008" shim to the exhaust follower, covering the worn area. The shim stayed in place long enough to check the timing figures over 1 cycle. The exhaust values were restored almost to maintenance book values. From that I think it will be worth having the followers restored to original profile, or at least a close approximation.
Cheers, Ian McD
Ian,
The club has a large number of prints of Norton drawings. Originally from Plumstead factory. Many of the prints are of spare parts being manufactured in the 60's for earlier, non current models. True rocking horse shit. A part number is the only way of searching the pile. Have you got the part numbers?
I don’t see it under SERVICES tab. Is there a catalogue to search? I have a couple of items that are “unobtainable” which could be made with moderate ease but the information from the correct drawing would ensure accuracy of detail. Who is the curator of these documents? Are they our IP?
cheers
Like Jon (I suspect) I am pleasantly surprised by this suggestion. How difficult would it be to search the archive - has someone compiled an index/database or would it be a physical trawl through a stack of drawings? It would be very useful if a copy of the original drawing was to turn up but I am preparing for disappointment!
Cheers, Ian McD
In reply to by ian_macdougall
Sorry Ian,
Not in the old prints.
The club have no original drawings.
You seem to be getting some useful help from some of the members.
All the best.
Much appreciated, certainly worth the try. I will ask Newman to make an educated guess based on the profile of the unworn side of the follower.
Cheers, Ian McD
Some time back, there was a spare parts WD16H Engine blueprint on eBay. I was outbid but managed to get some better scans from the buyer.
Obviously, a different period and engine so probably irrelevant and not dimensioned anyway, but it would be a shame not to share if there might be some information useful to someone who knows what they're doing.
Follower
Today we measured the best portions of 3 followers using radius gauge.  I have a link somewhere on the effects on combustion of late and early valve operation.  Will send it for interest value.
I have spoken to Newmans this morning and given them the 15/32" figure. Ken must have had my follower somewhere close by as he was able to say that mine is nearer 1/2" but not a constant radius. He will do as we discussed, build up the worn area then regrind to a close estimate of the original profile.
Richard's blueprint highlights another possible area of confusion. The part numbers on the blueprint of the later engine are the same as the earlier engines eg 9046 is the cam follower/rocker for the early 30s sidevalves and for the later engine shown above. There must have been several versions of the original detail drawings, plus information either on the drawing or in a separate document indicating the model year or engine number to which they apply. One less worry for us as we don't have the drawings anyway.
Thanks again for your help, hopefully the reprofiled followers will bring the valve timing of my engine back nearer to spec.
Cheers, Ian McD
After a longer than expected delay the cams and followers came back from Newmans and look good. Valve timing has been restored to book values. In the meantime I discovered that the valve guides also needed replacing and that further delayed the rebuild. Just this week the Model 18 went back on the road and is running so much nicer than before. Performance is crisper and once at cruising speed the throttle can be backed off to maintain that speed. Previously larger throttle openings were required just to maintain progress and it felt like there was little in reserve. A big improvement, definitely worth having the work done.
Cam Followers 1
Thanks Ian, I'm surprised that such an article included dimensioned drawings. I will look more closely at old copies of The Motorcycle when they come my way.
Ian, Just to correct the error, it was the Feb 19th issue of "The Green un" (Motorcycling) magazine not "The Motorcycle" as originally posted.
I remember the request for information on Model 18 Cam follower profile. The attached article from Motor Cycling April 1954 caught my eye in a junk shop in Settle. (Wife browsing new pullovers in adjacent shop). Now, I know nothing about Norton singles, being but 3 years old in 1954, but visually the bottom half of the sidevalve and OHV engines look similar.
To my eye some really useful information for Norton single owners. And a very good detailed drawing of cam follower at the end of page 2.
I’m hoping those interested can download and save/print the article. If you unable and would like this old magazine, email me directly. I’ve had my £2.50 worth and it cost me two new pullovers.
