000798 000801 000804 000807 000810 000813 000816 000819 000822 000825 000828 000831 000834 000837 000840 000843 000846 000849 000852 000855 000858 000861 000864 000867 000870 000873 000876 000879 000882 000883
Pushrod tube
Anyone know the size of the pushrod tubes?   Inside and outside diameters are the dimensions I'm looking for.
I have an idea I would like to try with the push rods, thats why I am asking for the dimensions, the wall thickness of the aluminium tube.
I may need to buy one so I can cut it up to determine this dimension, I would rather not do that.  I'm hoping someone will have a damaged rod that can be measured.
Anyone?
Thanks for that information Andy.  I did suspect that they might be solid rather than tube when I weighed them, 18 -19g each.
I am making a set of push rods in the the hope I can improve on the standard ones.  I'll share when the jobs done.
Privacy Policy
