Speedo face
Hi I have an NVT speedo on my 71 Commando and it should match the Green Globe Tacho, my question, can I  change the face or will I have to replace speedo.
Yes, get it refurbed and make the dial change part of the refurb or buy a dual and diy but it's not for the faint hearted.
Hi yes I believe it can be a DIY job but I think the glass rim is the problem(crimping it to body) any suggestions?
You need a lathe and a soft alloy tool or some other way to hold the body softly allowing it to turn slowly and a roller on a toolpost to roll the bezel over the side. One of these days I will set my lathe up to do this.
