Oil leaks
Just by way of an update and for the benefit of others I've been trying to stop my jubilee impersonating the Torre Canyon (google it if you need to!) while seriously thinking about it setting fireto it that probably isn't the best solution!
Stopping the gearbox was fairly easilysolved by using new o rings, however experience says they wont last very long. I haven't used the square section ones as I find them hard to get the shafts through.
My bigger problem was oil around the gearbox sprocket it was so bad the whole side of the bike was getting covered byoil. I have replaced thesleeve gear oil seal - no mean feat! its a tight fit but that didn't solve it, I also replaced theoil sealbehind the clutch in the chaincase, that didn't help much either although it seemed to be ok for a few miles. Which got me thinking ..... why would it start leaking after a while? So I dismantled the clutch side (again!),fitted another oil seal but this time I ran the engine with the cover off for a bit to see if I could find where the oil was coming from - clutch site or gearbox side. The gearbox side of the casesstayed dry but the chaincase started to fill with oil, closer inspection revealed that the oil is coming from behind the rotor around the crankshaft, it must be slowly overfilling the chaincase so that it eventually splashes out of the breather hole behind the clutch.
I thought I had replaced the crank seals but see that was on my Navigator, so new seals are ordered from the club - couldn't see a part number or size so I could order them from Simply bearings. Fingers crossed the bike will stop leaving a slug like trail of oil in its wake!I'll update when they arrive and are fitted.
Sounds familiar Dan, my Navigator crank shaft oil seal was leaking so badly into the primary chain case it was quickly over filling it with engine oil, making the clutch both slip and drag and then forcing its way past the clutch oil seal onto the chain to be sprayed across the back end of the bike! I stripped the whole primary side down, replaced the gearbox and clutch seals which weren't to bad to do. I then found someone had peened the crank case at three points to hold the crank seal (listed in NOC shop) in which made it a real pain to remove and an even bigger pain to replace - so much so that I damaged the first one and had to replace it. I used a copper scrapper to ease the peening back and then a thin film of lock tight to ensure the metal outer sealed in the crank case recess. I have done over 1000 miles since and the primary chain case oil level has stayed the same and apart from my stupid over filling of the oil tank the engine is staying 'sensibly' oil tight!
Nick
Iâve ordered an extra seal for just that eventuality! Peening the seals seems to have been the norm, but a real pita! I loctited the clutch seal in, it worked well but I had to apply some heat to get it out again! Iâll do the same with the crank seal. Someone had drilled the cases to tap out the main bearings at some time, I filled those with jbweld, Iâll be double checking that too!
Dan
Oil on the backwheel I found eventually was the crankcase breather. Either the the thread holding the breather pipe was leaking , or the tube not sealed all the way back to the oil tank. I sealed up the crankcase breather completely because it is a nightmare to sort you have to take the the primary chaincase to access. I tapped a nipple directly into the breather oilway as it decends from the crankase. I noticed with Ullies bike he has a breather tapped directly into the crankcase. Never had oil on the backwheel again. It transformed my bike .
GRAHAM
237-oilbr-002-jpg
Interesting! Iâve seen a couple like that, how did you keep the dwarf out of the crankcase?
Dan
By getting Snow White to hold their hand?
Sorry!
Dan
Hi Dan. Belt and braces:-
1.With the primary chaincase removed, remove the crankcase breather tube and the grub screw sealing the oilway. Clean the oilway of all oil so that swarf is less likely to stick.
2.Fit a dowl a slightly loose fit into the oilway. (it shows the direction and length of the oilway into the crankcase).
3.Drill a pilot hole to meet the oilway and dowel, when it tickles the dowl you know to stop. Clear the swarf from the hole that you drilled down to the dowl.
4. Measure the depth of the oilway that you drilled to. Drill and tap the new breather connection to that depth.
5. Remove the dowel. Pass pipe cleaners through your tapped hole and down the oilway where the dowel was removed.
6.connect your new breather connection. blow compressed air through your new connection exhausting through the original crankcase breather connections.
7. Remove your new breather and illuminate the passageways for debris.
8. Seal the original crankcase breather and refit the grub screw.
9.Assemble the engine , but feed the new crankcaase breather into a clean jar.
10. When you run the engine eventually, sumping from the crankcase will exhaust into the jam jar.
11. Inspect the oil for contamination. If clear you can be quietly confident to connect the crankcase breather to the oil tank.
12. If there is debris still there it will be captured by the fine gauze at the bottom of the oil tank, or if in the crankcase in the fine sump filter. If swarf is too smal to be stopped by filters it can be captured by remote oil filter you have fitted.
13 Change the oil after a brief running in.
If nothing else you can be sure the oil underneath your bike is not from the crankcase breather or from wet sumping.
GRAHAM
Thanks Graham
I may do that on my early Navigator, but for the moment the good news is having fitting a new crank seal, after a short run there was no oil where it shouldnât be, Iâm not counting my chickens yet but I may have solved the main leak!
Dan
