I met with a guy tonight who is putting together a package for Norton owners to basically have their alloy tanks wrapped in a clear coat ultra thin plastic. It is almost invisible to the eye but stops the tank getting scratched. In fact if the covering gets marked (by zips buttons etc) all you have to do is pour hot water over it and it reforms without the need to have it re coated. I am definitely interest and I will have some idea of prices etc as of tomorrow. Anyone else interested?
Hi Graham, A bit of a late…
I bought a roll of "helico…
I bought a roll of "helicopter tape" cut of about 300mm (1ft) cut a couple of darts either side and put it on the rear of the tank close to the seat. I used soapy water so I could position the tape and get the air bubbles out. It peals off easily if it gets scratched and a new piece is applied.
BTW Its called helicopter tape as it's apparently used on the leading edge of helicopter blades
Hello - thanks for this -…
Hello - thanks for this - I have used helicopter tape on my cycles for years but only as a narrow tape. How wide is the tape you got?
Hi All Sorry for the late…
Hi All
Sorry for the late reply I have been flat out at work. The guy I met is Alex Cullen and his company is Clearcoatscotland.co.uk Tel 01413635050
He covers the country doing work for high end dealers
Thanks for the info. I lik…
Thanks for the info. I like the 'covers the country' pun - I think you've created an advertising slogan for him.
Previously clive_astley-my…
Sorry for delay in reply. The tape I used is around 100mm wide. Works quite well, as it stops the buttons and zips from jacket scratching the tank.
Blade tape is good stuff u…
Blade tape is good stuff until it starts coming off your blades, then things can start getting interesting. It tends to go yellow over time and is quite thick. I use it for the rear edge of my Fastback tank to stop the sear chaffing the paint. You could also use clear fablon though the stuff I used to have access to was matt, we used it to cover charts for re-use
Previously david_evans wro…
The stuff I used was 3M, just measured it and it's 122mm wide.
Not too bad on flexibility as it follows the curves of the Dominator tank. It comes off quite easily and doesn't leave any residue. I plan to replace it every year so the yellowing shouldn't be a problem. I don't think I'll be subjecting it to the same punishment that the leading edge of a helicopter blade experiences
I should get 4 applications from the roll I bought. It suits me as I don't fancy covering the whole tank on a semi perminent basis.
Hi Graham,
A bit of a late posting as I'm only now about to pick up my new cafe racer. A local 'wrap' company in Birmingham can provide off the roll material and application kit as I was considering protecting the back of the tank only. What details do you have?
Regards,
Clive
