ES2 conrod
Hello, prior to having a new big end bearing fitted, I checked the conrod for twist and bend. I found it to be bent 70 thou out side to side. My question is, would it be ok to straighten it, either cold or heated up? Generally the rod is in good condition with no knocks or nicks.
any help or advice much appreciated
Martin
Old books like The Motorcyclist's Workshop used to describe how to do this, and I think I've seen it in Phil Irving's Motorcycle Engineering as well. I believe both recommend cold.
You do of course have to be careful not to cause any stress raisers.
Thanks for your input Gentlemen.
My apologies for not having replied earlier - some dashed bout of gastric flu.
Well you're both of a frame of mind it can be done, and it seems cold is the way to go.
Not quite up to going down the shed yet, but the attached picture has ideas forming based on what tackle I have. It's near as damn it 70 thou out, and with about 3 thou twist. To my thinking I'll get the bend out first, and one never knows, it might take the twist as well.
I'm in no rush to complete this, and that of fitting the new big end - its the last major job on the bike, and quite looking forward to it, now I see it's feasible.
It may be some weeks, but I will of course let you know how I go on.
Thanks again, Martin
I seem to remember that when these techniques are described they say to slightly overcorrect then finish by a slight correction in the originally bent direction. But my memory isn't what it was.....
In fact just checked in Tuning for Speed and that's what Phil Irving says so my memory's not too bad after all!
Success! After much checking of the rod as to where the centre of the bend was, I ended up with a setup similar in principal to Davids attached picture.
I packed the conrod level under the big end eye, and on top of my 1/2" plate steel table, close enough to the edge to be within reach of applying pressure by clamping down with a medium bench vice. A 3/4" x 3/4" x 2" steel block was placed across the rod at bend centre to focus the vice jaw pressure.
With no idea how the rod would give, i didnt go mad. I started off applying bend of about 1/16" but it sprang back. I'd measured the rod to be out by .070", so a bend back to centre of .035"
was needed. These are a strong rod, and eventually, clamping to bend the rod to around 1/4" to 5/16" produced the desired result. Checking for squareness between the big end eye and gudgeon pin showed it wasnt far off. Prior to straightening a 1/16" to nothing gap was seen at the gudgeon pin (touching at the top of pin) and when rod was turned over touched at the bottom.
