bellmouths on concentric carbs
Probably a stupid question but how do I get my Bellmouths off. I thought they just screwed on but they seem very very tight. Thanks in advance.
Hi, they do just screw on,are the carbs still bolted to the head?usually there is a flat spot filed on each bellmouth because of clearance try loosening one carb with your cut down allen key,if still no joy someone has probably glued them on or cross threaded them!
good luck regards nick
