650SS speed to revs
Does anybody know the ratio of speed to revs for a 1966 650SS? In top, mine is doing 45mph at 3000rpm. After 22 years in the shed it's had a 2 year longrebuild and a Mick Hemming's(Norvil?) "Dominator"primary belt drive installed. I seem to recall that, whenI previously rodeit 24 years ago, 3000rpm was over 50mph. Is that my memory at fault or is something now amiss, such as the belt drive upsetting the ratios? The gearbox sprocket is 19T. Any advice will be gratefully received.
My mercury is being reassembled at present and my gearbox sprocket is a 21t. Perhaps thats the difference in ratio.
Hi Paul. using my Speed v revs Calculator (SEE SEPERATE MESSAGE) your TRUE speed at 3000 revs and a 19T gearbox sprocket will be just over 51 MPH.
So at 7000 RPM, top speed should be 120 MPH...sounds about right to me.
Les
Les
Hi Les
On the basis of the above do you think my 21t gearbox sprocket is too large? Waht would the top speed be with a 21t on your calculator? What figure are you using as the rear wheel circumfenence?
Dominic
Hi Dominic. With a 21 tooth gearbox sprocket your overall top gear ratio is 43/21 x 42/21 = 4.095.
My formulawill give a theoretical maximum speeddepending on the revs chosen to give peak power output. So if we say the peak power on a Mercury is produced at 6000 RPM then the theoretical top speed will be 113.4 MPH.
In practice the top speed will only be achieved if you can produce enough engine power to match the wind resistance and tyre friction and losses in the transmission. If you over gear your bike the top speed is likely to be lower as the engine cannot produce enough power to match the power requirement for the theoretical top speed. I would say an unfaired large motorbike requires around 50 BHP to push 113 MPH so your Mercury is not going to get anywhere near thatspeed if the engine is standard.
However over gearing will mean lower cruising revs, less vibes, and less wear. The acceleration will not be as quick though.
This is why I suggested the calculators are useful for obtaining the best match for revs v top speed v actual desired style of riding.
The wheel circumference will generally match 19" x 3.50-4.10 tyres quite well. I'm not saying it is accurate to the nearest 1/10 of a MPH etc, but it will be quite close in practice.
Les H
Hi Les thanks for that. I went and counted teeth after reading your message. I have 21/42 and 21/42 both primary and final drives. The mercury in theory put out 47bhp. Be interesting to see what it will attain once I have it complete. Strangely the speedo fd is 19/10.
regards
Dominic
Hi, guys. Many thanks for your interest.
Anna. WhenI originally wrote my question I put that I remembered my bike as doing 60mph at 3000rpm. I altered the text because maybe my memorywas wrong. It seems it is right. So, thank you for confirming what I remember,60mphis 3000revs.
Leslie. Thank you for attempting to calculate the result. As I said, the speedo and rev counter are confirmed accurate and the bike is pulling 45mph at 3000rpm.Could it be thatyour calcs come up with a different answer because your are basing them on the use of a standard engine sprocket, whereas my bike has a belt drive pulley of unknown size?
Dominic. I guess this is where I am heading, towards a larger gearbox sprocket.
If anybody else has an opinion, I would be pleased to receive it. The best would be from someone who has also fitted a belt drive to an SS. Ilooks likemy next step is to have a chat with Mick Hemmings.
Hi Paul. I think you have forgotten your own question maybe?
Of course I worked it out for a standard set up!
You were suggesting that before you changed to a belt drive the speed was in excess of 50 mph and I have shown you were correct with your memory. In so doing I have proved your suspicion that the belt drive is giving you a different gearing. If you would like to take the time to count the teeth on the belt drive pulley cogs I will happily tell you what speed you should be getting now and tell you what new gearbox sprocket you require.
I have simply shown what you asked for, there is nothing more really to add, apart from counting the teeth of the new set up.
Les
PS.For a high power drive, it is beneficial to drive the clutch faster (have less primary reduction) This reduces the torque on the clutch and reduces the chance of clutch slip. One then has to compensate this speed loss with a larger gearbox sprocket. If the new primary ratio is known then a new secondary ratio can be calculated to compensate and get back to the old overall ration (near to). I would imagine this ishowthe belt drivehas been designed.
Les
CORRECTION: I said:
PS.For a high power drive, it is beneficial to drive the clutch faster (have less primary reduction) This reduces the torque on the clutch and reduces the chance of clutch slip. One then has to compensate this speed GAIN with aSMALLER gearbox sprocket.
So Paul, as your new speed is slower then the primary ratio is giving you a greater REDUCTION,ie: the clutch is turned more slowly, which is surprising and different to what I had imagined.
The speed difference (51mph down to 45mph) is 6% slower so you will need to increase the rear sprocket to give an extra 6% higher ratio.
So the nearest gearbox sprocket will be a 20 tooth one to replace the 19t which is standard.
This will get back you back to over 50mph at 3000 revs.
Les
HI, Les. True. I forgot my own question. Irealised that the next day.My apologies
I was surprised by the 51mph, I did think it was in excess of that, plus I wasn't aware an SS would rev to 7000.Sometime soon I will check the number of teeth on the pulley and maybe take you up on your offer.
Hi Paul
Hopefully I can shed some light on this! I too have a 650SS with Norvil belt primary drive, this gears down the final gearing somewhat, I used a 22 tooth gear box sprocket which gave great cruising but relaxed acceleration, a 21 tooth is much better giving about 3000 revs= 60mph etc, this seems a good compromise between acceleration and cruising. hope that helps.
Nigel
Hi Paul
Nigel
Thanks, Nigel. I've found a guy at work with an SS with a rev meter. The next time he rides it he will take note of the speed/revs and report back. Then I think I can make a decision. But, from all the info in these messages, it's obvious 20Thas to be theminimum and like 21T is a strongcontender. I'll post what else I find and what I decide.
