Laydown gearbox kickstart shaft washer
Hi there all. Could someone let me know please where I can get the "kickstart axle cork washer"....Part number A2/355. It's a flat cork washer 9seal) taht fits on the inside of the inner cover at the back of the kickstart ratchet to stop oil flow along the shaft.
Modern alternative type might well be made of rubber etc, but I don't know. I was thinking that if they're not available a 28mm IDX 2mm O ring might work?
The other thing I noticed is that the shaft has two quite deep oil grooves just over half way along it and one could imagine that a thin (1.5mm) O ring could be fitted into one of the grooves to aid oil tightness too.I wonder if anyone has tried this please?
Many thanks.
Les
hello Les Is This For A 1954 Dominator 88 or model 7 As I have a 1954 Dominator model 88 but my one as a semi-close ratio Inter Custer In My gear Box As The Gear Ratio's are higher than the one my friend as and I have ridden his bike and he as ridden my bike and even he say my bike as a high gear ratio also, I have big drawing of this lay-down gear box so it will show where this cork washer goes ?
Hello Anna. Thanks for your reply on this and my earlier request for a source of spares on another message. I did manage to get all I needed (not much required it turned out) from RGM. The full bearing set was bought from Simply Bearings at a pretty good price with fast and cheap delivery.
Just to say; I know where the cork seal is fitted, thank you,but I wanted to know where I could BUY one. I have ordered some O rings to experiment with fitting some to the kickstart shaft without doing any modification. I'll let you know if this is successful or not.
I wouldSTILL like to buya kickstartshaft oil seal or washer though. It's strange that with all the members in this NOC that apparantly NO-ONE knows. very odd! You don't have one do you Anna?
Les
LP, I made seals from both cork sheet and klingerite, neither stopped the leakage. The principle is all wrong,there is no compression applied to this area unless you end load the layshaft,[ not advisable.] I enlarged the outer of the two grooves in the k/s shaft to take an eighth series O ring[3.2 mm], fitted same and no more leak. Suggest enlarging the outer groove as the inner one may correspond to the internal drilling. John.
Les Hello Les I will Have Rummage in my parts boxs and see what I can find If I have One You are Welcome too It, and it will not cost you anything, as I am to pleased to help? your Anna J
Thanks very your reply John. I was thinking of doing the same with some cork sheet. I think you have to get the old original anduntreated cork, the resason being that corks expands when in oil or petrol which is how petrol taps use it. My old cork washer (split) was around 2" squashed hard and dried out. The ability for the cork to swell exerts the sealing pressure. I think yourmodis best and should work excellently. Unfortunately I don't have a lathe. I tried a few o rings in the standard groove. the ideal thickness is I would say, 1.2mm. I have managed to get 1mm in the standard groovesbut they are just a fraction too loose in the bore. and 1.5 is too big. By the way,I don't have any internal drilling as you mention so both mygrooves can be used. I'll see how it goes (probably take another year to finish the bike) It's an easy part to remove, not loosing much oil either.
Hi Anna, thanks for kind offer to look for the cork seal. Would appreciate it if you do find one, I'd like to fit it just to see how well or not it does.
ATB to you both.
Les
ATB to you both.
Les
CORRECTION: OLD CORK WASHER WAS SQUASHED TO ABOUT 2MM (NOT 2")
LES
LP, the drilling to which I refer is the internal cavity in the K/S shaft which provides a home for the layshaft bush.This depth can be variable and may not have been toleranced on the drawings, but left to the judgement of the machine setter.I cant remember the relevant dimensions, but I remember thinking that it might be a trap for beginners. We have all parted a component in two with a groove or a bore, but its funny only when it belongs to someone else.Regards John.
Thanks John I have the picture now. I was imagining the drilling you mentioned was a hole that pierced through the kickstart bush (tube) . I can see what you mean now.
ATB
Les
