NOC Shop head bearings
Does anybody know if the tapered head race bearings in the NOC shop are a direct swap for the cup,coneand ball bearing type with no machining requirement, thanks in advance, Mark
Hello is this to fit into a featherbed frame , then if it is , then yes they should fit , but ask Neil Shoosmith first , You will have to catch in he works some Late hours .And All the EC work force Are all voluntary workers trying there best too help all members !
Hi, thanks for the reply, yes 'tis a featherbed. I've had a reply from Dale too, I understand about the workforce, many thanks to them. Also since the question I've took the trouble to do a site search, perhaps I should have done that first so apologies if it seemed a tad impatient.
Mark
