Short or Long Roadholder oil seal holders
Can anybody tell me the lengths of short and long Roadholder fork oil seal holders ? Trying to buy a set for a 62`Dommie i am working on, pretty sure i have short ones, but want to make sure before i order some new ones.
Cheers Ian
Cheers Ian
Ian Hi - i have just measured mine from a Mercury (late 650) and they are 70mm long (not counting the threaded part that screws into the slider). Remember there are at least two types for the short roadholders- mine from the 650 have a stengthening taper within so could not be used with external springs. Early ones have a neat step inside to facilitate the external spring (if fitted). Also some have holes for the special spanner for tightening whist later ones do not.
Regards, Howard
Ian - further to previous response I've looked at a pair of long roadholders from a Model 7 and they have a separate oil-seal holder and shroud (tube), with the shroud fitting neatly over the slider so covering the seal holder. I don't know how long the Commando, Matchless hybrids or Navigator ones are but on a 62 Dommie you'll be ok with 70mm. Cheers , Howard
