Missing engine parts?
Hello all, I have a 1962 slimline 99 and have removed all parts from the timing side and according to the parts list there should be a Sealing washer for timing side bearing Part No T2008 and a Backing plate for pinion Part No T2007. Did they fit these parts to the later 99 and where are they fitted. The engine has 14 stamped on the crank case. Many thanks. Jim
On the timing side main there should be a dished washer and then a triangular thick washer which fits behind the half time pinion. Should be there on all twins.
Thanks for that. Are they on the inside or outside of the crankcase. Jim
