Mercury - what's missing?
Back again
I am fitting the front pegs and something must be missing I have looked in the parts manual,but it shows the wrong side and I cannot make it out
The lhs all makes sence
The rhs I must be missing a retainer or bracket....I'll do my best to explain...
Is there a bracket/locking fixing that goes between the peg and the frame plate...I guess it would have a crown/ segregated face on the peg side and on the frame plate side a flat with 1 if not 2 oblong locating lugs so the peg won't swivel ....that locks into the frame plate...
That's it really
http://s1281.photobucket.com/user/Mjc477/media/image_zps6cb5b572.jpg.html
Cheers in advance
5 pints.?????
That's almost equivalent to £20
Still I have to have one
Also is the rhs peg then held on with a long cylindrical nut as that's what I had screwed on the end of the rod in the box when I got it. It doesn't look correct???
I do have the spacer tube....
And can you point me in the right direction as to where I can get the retaining disc from
