Could you tell me please
Where do i put this plate? In front or left side?
Thank youAttachments
c-jpg
It is a splendid plate but…
Thank you, and who can giv…
Thank you,
andwho cangive mea document that Dominator did not have it.??
Of course there is no docu…
Of course there is no document to show that something was not there. It is like trying to prove a negative. Jut not possible!
Lubos: The plate you are s…
Lubos:
The plate you are showing would have been mounted on a Commando model and was not used on anything else. On a Commando it was located on the steering head as per your photo. It would have been facing forward.
Have you found the original frame number on the left hand side swing arm gusset as Gordon stated?
These plates have a clearl…
These plates have a clearly European form and I believe are sold in Germany. Germany had a requirement dating back before WW2 that motorcycles be fitted with a data plate including year of manufacture and cubic capacity. Something to do with 'Type Approval', probably, even at that early date.
If these (or something similar) were fitted to Norton Dominators, then it would have been done by the German importer and fitted to a location chosen by him and accepted by the authorities.
I'd suggest asking Norton Deutschland, or the former Norton importer for the country where you're located.
Hello I understand what yo…
HelloI understand what you writing me.i found number on the engine and frame as well.I am asking because our councils require factory plate on motorbike.(small metal label with all origin details-serial numbers etc..)If bike never had factory plate i need to prove it here on councils and thats why i need confirmation from manufacturerI need to registrate bike in Slovakiaregards Lubos
This sort of certification…
This sort of certification label was not fitted by the Norton factory and would indeed have been the responsibility of the local importer. The problem that you have is that Nortons were probably not imported to the former Czechoslovakia after 1939. There was a consignment of ES2 models as part of a trade deal in 1959 but I believe these were for a government agency.
The NOC had quite a strong presence in Czechoslovakia at one time (they even organised an International Rally). I suspect that you could best ask a local Norton owner what is fitted...or maybe fit the plate that you have. The reason that they are available is probably that many European owners do just that to avoid any problems.
As it's not original, it's up to you which discrete place you choose for it.
Hi Lubos, If you fit your…
Hi Lubos,
If you fit your plate as you show in the photo it will be covered by the 'shroud' that fits to the two mounting holes......guess that would cause problems with your 'council' people.
regards John
It is a splendid plate but Dominators did not have then fitted when new. The Dominators simply had the frame number stamped on the left side gusset, just above the hole for the swinging arm in the form:
R14
85787
for example. In this case a Norton 99.
