I have Domi 500 1953 Model 88 (cast iron head), its fitted with a worn Amal 76AS.
Does anyone know what it should be fitted with ?
The Amal catalogue starts Model 88's at 1955 with a Monobloc 376/19
Neil
Previously neil_blakeway w…
That's interesting!..read…
That's interesting!..reading from my Amal carbutettor list No. 440, dated February1956, thatfor the 497cc twin Dominator1949 - 1954, they were fitted with a 76AK/1AT carburettor. Apart from other things, 1" bore, 170 main jet, size 6 slide with 3 1/2 cut away, 2 needle clip position.etc, as previously stated.This is a pre-monoblok type wich has no removable idle jet, only drillings in the body. The 1AT bowl is angled at 7deg.
The 76AS unit you have came off a 1953 Triumph Tiger 100C, which were a twin carb bike, the AS being the L/H one which originally had a smaller main jet and bigger (leaner running) No.4cut away on the air slide. These which probably have been changed in a 60 year old carb.
Previously anna jeannette…
Neil
The right carburettor you need is 1952-54 = pre -monobloc 276- AK/1TK 1inch bore main jet 170 ,pilot jet 30 cutaway side 6/3.1/2 needle pos 2... needle .107
yours anna j
Thanks anna for the information
I am woundering if it best to fit a Monobloc, accorder to the Amal book, they are an upgrade in performance.
Neil
Previously Paul Knapp wrot…
Thank Paul
This may explain why it has never run too well. I am woundering if an upgrade to the 376 may be best.
Neil
That's interesting!..reading from my Amal carburettor list No. 440, dated February1956, thatfor the 497cc twin Dominator1949 - 1954, they were fitted with a 76AK/1AT carburettor. Apart from other things, 1" bore, 170 main jet, size 6 slide with 3 1/2 cut away, 2 needle clip position.etc, as previously stated.This is a per-monobloc type witch has no removable idle jet, only drilling in the body. The 1AT bowl is angled at 7deg.
Thank Paul
This may explain why it has never run too well. I am wondering if an upgrade to the 376 may be best.
Neil
well i had my original carburettor a 276.AK/1AT from my 1954 dominator 88 reconditioned by Martin Bratbury for around £100 and it runs fine now , so you can give him a try, yours anna J
yours anna j
