Identification number of series 650SS 1964
hello, for the acquisition of the 88 SS norton 1964 serial number 88 SS /107207/P
I not known if the number corresponds to a model 88 SS 1964 ?
tank you for answer . cordialy . bernard (norton owners club French)
Hello Bernard Your Machine should be stamped 122-107207/P and the 88ss at the back of the block and the P is for Police so this Machine is a 500cc NOT a 650cc Machine as all 650's are stamped with 18 or 18ss hope this helps
Bernard is asking if his Norton is from 1964. Bernard, your Norton is from 1963. I have a spare engine with a serial number very close to yours in my basement, and I also have two complete 1962 Norton 88ss bikes for reference.
Anna Dixon, you need to learn more about Norton twin engine stampings before you give further advice because you are wrong on a few points, and I have seen you give wrong information to others also in this area.
Only 1962 and earlier Norton heavy twins are stamped with data on the back by the breather, later Nortons have nothing there, and the "P" does not stand for Police, as almost ALL 1963 heavy twins are stamped with a "P' in their serial number, the year Norton moved production to PLUMSTEAD, and that is what the P in the serial number stands for in this year.
So Bernard you have a 1963 500cc 88ss .
Here is a helpful chart from the Norvil website: http://www.norvilmotorcycle.co.uk/engrange.htm
Norton changed the numbering system on crankcases a few times after Bracebridge street was abandoned. In 1964 you will see the 500cc and 650cc engine cases with "122ss" and "18ss" as part of their number, then in 1965 there was no more "ss" stamping and instead there was an "M" in the engine serial number.
This information is all first hand from the stampings on the eight model 88, 99 and 650cc complete motorcycles I have owned and also an easy dozen+ extra engines and crankcases I have for 500-650cc dominators, not to mention looking at dozens Dominators over the decades owned by others and recording the numbers from them.
Short note just to confirm that all Lightweight Twins carrying 'P' as part of the engine & frame number were made in Plumstead (the home of AJS & Matchless). Indeed, the first Norton to be made there was a Navigator. See attached picture for an example of a Norton Navigator frame number made at Plumstead.
"then in 1965 there was no more ss stamping and instead there was an M in the engine serial number" Thats odd because my 1967 650 ss has the the engine number 18ss 123xxx and no M.
1970 Mercury: 18SS/129xxx/P and no M.
Hello I see You Have Send My Deliberate Mistake That Got You all Writing In Too Jump All over Me Do you Think I am some Blond bimbo with on Brains ? I have Been Riding Norton Motorcycles 40yearsSo Bewhere I with Be Testing You ???
Hello anna, thank you for the informations, but I made a mistake on the N? bad transmission on my part the N? correct are (18SS/107207/P) Sorry for my english. Bernard
Right, if you read more carefully and make fewer assumptions, I said "in" and not "after". I have no 1967 engines to comment on, so since you do thanks for adding a piece to the puzzle....
Hello everybody
Just thought that I would chuck a few words into this muddle.
My Commando has an M in its engine number but no P.As in 20/M3S/ 150***
My two 1967 Atlas engines also do not have any Ms. ie 20/120*** & 20/123***. My 1965 Atlas does have a P but no M. ie 20/113***/P. Just in case the blond bimber with 'on brians' is reading, the real numbers do not have asterists in them either. Data Protection Act.
Have I lost some Ms & Pssomewhere?
Moving on.......I am now going to throw some stones!!!
Page 6 in the 2010 Norvil Catalogue informs the world that the first Norton 650 was engine number 100200 and arrived on the scene in October 1961. They have beengiving this info out for quite a few years now. Whereas, those NOC people with the actual factory records will tell you that 650 engined bikeswere being built around 12 months earlier with most machines heading for the USA by December 1960. Engine number 93601 being recognised as the firstin this Norton 650 Manxman group.
Engine number stampings appear to depend upon who was 'stampman' on the day at the factory. I have come across 122SS, 88SS, 18SS & 650SS stamped on various Norton engines from 1960 onwards. Somebody must know why.
The first batch of 650 engines were sold in both single and twin carb forms andhad 18 stamped on the crankcases, front left and 650 at the back by the breather.
.............and what about the engine numbers stamped Mercury models of circa 1969/70?
Bernard needs to contact the NOC Librarian who will probably be able to help sort out whenhis bike was actually built.
Hello everybody
Hello Phill As The Blonde Bimbo With NO Brians ? The NOC Librarian can only give the infomation On the Factory Records This does NOT mean That your Bike Was built one THAT DAY As Recorded ,As The Records And Stamp-man Could up to 2 Weeks Behind Hand ? As Bracebridge StreetWas a Small Factory Compared With Triumph And BSA ? And Norton Built Motorcyles in batchs of 30 a Day , Yours The Blonde Bimbo? Anna J Dixon Secretary East Yorkshire Branch
"The first batch of 650 engines were sold in both single and twin carb forms andhad 18 stamped on the crankcases, front left and 650 at the back by the breather."
I have the 2nd Norton 650 built and an acquaintance of mine here in the USA has the thirteenth, and they are both dual carburettor american spec Manxmans. They do not have 650 stamped by the breather, in fact I have had two Manxman motorcycles myself, looked at many more, and have half a dozen extra manxman engines and none of them had 650 stamped on them, they have either "65" or "65C" stamped on the back. I am sure that "65C" does not refer to a bike with coil ignition either, as every single American spec Manxman I have seen with this stamping has a k2fc magneto on it.
I have model 88ss, 99, Manxman and 650ss engines and motorcycles dating from 1959 through 1965 and the stampings are consistent in each year, but they are not consistent from one year to the next. We have heard from owners of engines and bikes from throughout the sixties and it is interesting to see their engine stampings from each year.
The numbers on engine crankcases WERE very consistent and made a lot of sense year to year at the original Bracebridge Street factory, but from 1963-on when production moved to the AMC works is when the engine stamping system seems to have changed from year to year. Thank goodness they at least kept the actual serial numbers going!
Hello everybody
WOW.................. THINGS ARE HOTTING UP IN THE NORTON OWNERS CLUB, PITY I CANNOT HAVE SOME OF THIS HEAT IN MY GARAGE ON THESE COLD WINTER NIGHTS
hello adrian you could allways give me a hugg to keep warm In your garage ? yours Theauburn Bimbo now ? but I am no Bimbo ? the spelling misstake is not down me its my keyboard that goes wonkey now and then , I am getting a new computer soon ? yours anna j dixon
Very interesting (and entertaining) thread here. So I have a question - were the earliest 650SS's all stamped with 650SS on the back of the crank case (shop engine number area), or were they simply stamped 650? If just 650, any way to tell if it was originally a 650SS, or a Manxman that has been turned into a 650SS? Or is there rally any difference?
Peter B.
USA
Peter B.
USA
Hello Peter B Well The First Norton 650 Was The Manxman and The Fisrt 30 Machine rolled of the line on the 7th of November 1960 these continued untill September 1961 with Manxman was Sold In the UK As Manxman SS These had 650 SS Stamed on the back just above the breather pipe and slod for one month then things changed the name Manxman was dropped and 650 Sport special was adopted And the paint work was changed to black&sliver A Mans Colour ?along with a new parts manual ? So That Leves The Norton Manxman As a Limited addition as there was only some 800 or so built ? and the lots of changes made to the 650SS the frames lugs are in diffrent places to the manxman not notest until you get your tape mesuer out ? the tanks there bigger and back wheel had gone from wm3,18inch too wm2,19inch the seat pan had changed and the handel bar had changed So there are a lot of differentes between the two machines ? Hope This Helps Your Anna J Dixon A Norton Manxman 650cc Owner
Peter B.
USA
Very helpful, thanks Anna!
Peter B.
" and the lots of changes made to the 650SS the frames lugs are in diffrent places to the manxman not notest until you get your tape mesuer out ? the tanks there bigger and back wheel had gone from wm3,18inch too wm2,19inch the seat pan had changed and the handel bar had changed So there are a lot of differentes between the two machines ? Hope This Helps Your Anna J Dixon A Norton Manxman 650cc Owner"
Frame lugs on Manxman and 650ss are identical as long as the 650ss and Manxman are both manufactured at Bracebridge Street. It was when Norton production was moved to the AMC works that the front engine mounts were not relocated, but merely turned upside-down....
Many 650ss bikes were sold in the USA with the exact same fuel tank as the Manxman. Also, 650ss bikes sold in the USA had the exact same 18" rear wheel as the Manxman. The early 1962 USA 650ss bikes were in fact identical to the blue Norton Manxman except for paint color, mufflers, and the rev-counter being optional instead of standard, and of course they were stamped "650ss" on the engine.
As this thread involves a number of members with post 63/64 featherbeds, could I enquire if any of you are aware that your roadholder forks are not 'short roadholders' but contain longer springs (as in 'long roadholders) and longer damper tubes - see thread "fork shrouds", particularly input from Bill.
Matt
auburn huh......... i have never seen you so i would not know,,,,,,,,,,,i never saw this.....so..... what on earth did i say ?? what ever it was it was meant as a joke , certainly not as an insult. feb 2011
Ah...................... now i remember ........................ no insult there, certainly not meant with any malice ...... just my odd sense of humour .
please could you tell me of any differences in wideline to slimline swinging arms if you know of any , thanks
ah , but thinking about it , i am single ... and could do with an auburn haired friend with a couple of 'on the road' Nortons to ride on special occasions
Hi Bernard, I have a 1963 650ss, engine number 18SS/107263/P this is not very far away from your 107207. The frame number on my bike is also the same. My bike was first registered in the UK on 9th September 1963. I hope this may help.
Hi i am looking at buying a 500SS - 1963 model.
Was wondering if someone could help me on the numbers part.
Chassis No starts with: 122
Engine No starts with: 104
Could someone help me to know if it sound right? Matching numbers & an actual 500SS
1963 model?
Thanks in advance!
1963 model?
Thanks in advance!
Hello Marcus No The Engine And Frame Numbers start with the same number ,ie j122 54698 engine number frame number j122 54698 . Do you see ? if it was a 1963 some numbers changed to 88ss .then the number, but the 500cc super sport model 88 was built from april 1961 , it had the 650cc Manxman Crankcases and camshaft and camfollowers and pushrods ,and valves too and the multi- rate valve springs ,coloures where Green and Dove grey up to 1962/3 ,sliver and black after that date up too 1966 when this model was dropped from the range , hope this may help a bit ? your AJDixon
Well this is certainly doing my head in ! So who can decipher this number supposedly a 1961 650SS.
100783 18
Should or shouldn't the 18 have SS stamped next to it. I have only seen a photo of the number and not very good quality at that but the number on the crankcase appears to be 18 then an oval shaped red Norton Plate next to it. The rest of the number is further to the front hidden behind horn in this picture. You can just make out last two digits. Is this normal ?
Did you send the numbers off this bike to the NOC and ask for a records check? The first year for the 650ss model was 1962, and they were stamped "650ss" on the back of the cases where the engine crankcase breather exits, along with the engine shop number. After AMC took over production they changed the way the engines were stamped, marking some 650ss bikes with an "18SS" around 1963-64' and later on changed the stamping more than once before production ended.
The earliest 1962 650ss I have seen was stamped 995xx, more than a thousand bikes before this one, so it is not an especially early bike.
Norton still had non-SS 650 twins available for sale in 1962, so if there is no "650ss" stamping on the cases where it should be, then it would be a bike that originally left the factory as a 650 Standard or DeLuxe model, and might be stamped with a "65" or "65C" or just plain "650" back by the breather. I would not know for sure about all the stampings on the 650 Standard or DeLuxe as I have never seen one first-hand, they seem to be much, much more rare than the 650ss bikes!
I would not be surprised after all these years if most 650 Standard or 650 Deluxe bikes were re-done by young men wanting a more sporting bike to mimic the 650ss by fitting twin carbs and switching to the 650ss paint scheme...... I have seen some of the DeLuxe model 88 and 99 bikes with their special body-work first-hand, and am glad that at least a few have made it through intact over the last 50 years....
Thanks for that Benjamin. I will endeavour to find out from the current owner if there is any numbers by the breather. It is currently for sale so figured sending off to the NOC would take to long and might miss out if I decide to purchase.
No more numbers on the crankcase but it has 650ss (942) marked on the head. I guess this indicates that it was probably a standard 650 with a ss head fitted.
Hello Glen Well your Machine is Stamped correctly For a very late 1961 machine ,It should Have 650SS at the back of the crankcase just above the breath pipe and then the Workshop number , The first 650cc machine too be built was 18-93601 , It was pulled off the line for some reason maybe for testing , But it ended up with the Workshop number being 7 and the next machine 18-93602 being stamped number 1 , All 650 Manxman's was Stamp marked 65 or 65C . The De-luxe model was Stamped 18D on the side of the crankcases And standard machine just had 650 Stamped on the back of the crankcases there where not many built ,and same for the De-lux models too . And later all 650SS had a Stamp marked 18SS on the side of the crankcases. Now this information is from the Factory records And I hope This May Help!
Thanks Anna, See my reply to Benjamin above yours. The owner got back to me and said there was no numbers on the crankcase near the breather but the 650ss (942) was marked on the head. I think I've read elsewhere in this thread, or somewhere else, it depends on who was doing the stamping on the day. Who knows, maybe the bloke stamping that day was a little under the weather from the previous night and forgot to stamp anything near the breather !
Oops! wrong serial number. It is 18SS/129857/P
My 1970 Mercury engine and frame number is 18SS/129643/P. According to the "lore", the Mercury was manufactured from late 1968 to early 1970 and my serial number is supposed to be towards the very end of the run. OK, then why is there also a headstock plate with the serial number and a build date of 12/68? I've seen another 650SS with a stamped plate riveted to the normal place where the serial number is stamped into the frame. Was there any consistency?
My 1969 mercury engine number is 18ss/129496/P just for interest.
Hello yes may be the Stamp man had been on a bender the night before and was still drunk ! it happens yours Anna J
I know this is a vey old thread, but if there were no 1965 650`s with the "18SS" suffix made in 1965, then why does my 1965 650SS (registered 04/06/1965, have the "18SS" suffix?.
My 1961 Manxman engine has the engine number followed by 18 after and near to the Norton badge. It also has just 65 and a shop number near the breather. My Mercury engine had 18SS as a prefix to the engine number. It has no shop number stamped but there is one recorded in the Factory Records.
There have always been anomalies with regard to engine, frame and gearbox numbers on these bikes. As Anna pointed out earlier in this thread a change of shift could result in a change in the stamping pattern. I have seen engines with a variety of stampings and believe that a good many were genuine. This includes 18 or 18SS on the front as a prefix to the number and also on the crankcase side. The breather section also gets the Heinz Soup treatment with 65, 65C, 650, 650SS and nothing sometimes stamped. Plus don't forget that the very short run of DeLuxe engines had a letted 'D' added as a suffix so around 60 plus18D engines were built in the early 1960s as well.
For those of you who enjoy trying to ponder puzzling moments in the history of these bikes. Here are a few more to consider. 1) Apart from the barrels, the Mercury engines used Commando castings for the major components. 2) The last of the hybrid bikes also used Commando castings but the cylinder heads were machined to take the old top oil feed arrangement. So all the 750 and 650 engines at that time used the same 06 0380 casting. 3) The last official Factory Mercury produced was number 18SS 129894 in February 1970 but Mercury 18SS 129896 arrived at Gus Khun Motors in April 1970.
FWIW
Four more data points on engine cases
1961 right?
94449 18 65 123
94516 18 65 193
95109 18 65C 329
My cases 1962
100213 18 650 793
Do the factory records show if these are :
650
Manxman
650D
650ss
Mercury
?? yes/no/partial/inconsistent
thanks
Previously david_comeau wrote:
FWIW
1961 right?
94449 18 65 123
94516 18 65 193
95109 18 65C 329
My cases 1962
100213 18 650 793
650
Manxman
650D
650ss
Mercury
thanks
Hello Now the Shop Number Do not run in Number order , lots of machine where pulled of line for one reason or another, , But your Motorcycle is 18-100213 Stamped 650 -shop number 793 Now this machine it up to now the earliest found thats a Standard Model 650 , they where painted in metallic Dark Grey Known Has Smoke Grey Met, and would of had a two-tone grey seat ,and 3.1/2 gallon tank these machnie also had a Single caburettor fittings .And there where very little in the way of Chrome plating other than handle bars and exhausts and wheel rims , Nuts and bolts where in bright nickle plate . wheel sizes as 650ss 3.00 x19 front and 3.50x19 rear the other number you have put on hear realate to Norton Manxman 650 they where stamp marked 65 or 65C there Engine and frame numbers strats at 18-93601, 65 Shop Number 7 now the second machine built was number 18-93602 -65 Shop number 1 and third Machine built was Number 18- 93603 -65 Shop number 2 on the first day of manufacure where was 30 machines built, some may not of been completed with minor parts missing or wanting too be fitted, this is why the Shop number do not follow in numrical order , this is information sent too me by good people in the NOC , there from the Factory records , Yours Anna J
FWIW
1961 right?
94449 18 65 123
94516 18 65 193
95109 18 65C 329
My cases 1962
100213 18 650 793
650
Manxman
650D
650ss
Mercury
thanks
Hello Now the Shop Number Do not run in Number order , lots of machine where pulled of line for one reason or another, , But your Motorcycle is 18-100213 Stamped 650 -shop number 793 Now this machine up to now the earliest found Has A Standard Model 650 , they where painted in metallic Dark Grey Known Has Smoke Grey Met, and would of had a two-tone grey seat ,and 3.1/2 gallon tank these machnie also had a Single caburettor fittings .And there where very little in the way of Chrome plating other than handle bars and exhausts and wheel rims , Nuts and bolts where in bright nickle plate . wheel sizes as 650ss 3.00 x19 front and 3.50x19 rear the other number you have put on hear realate to Norton Manxman 650 they where stamp marked 65 or 65C there Engine and frame numbers starts at 18-93601, 65 Shop Number 7 now the second machine built was number 18-93602 -65 Shop number 1 and third Machine built was Number 18- 93603 -65 Shop number 2 on the first day of manufacure where was 30 machines built, some may not of been completed with minor parts missing or wanting too be fitted, this is why the Shop number do not follow in numrical order , this is information sent too me by good people in the NOC , there from the Factory records , Yours Anna J
Hello one more thing 18D is for De-lux Models Now Has for the Sports Models the first ones where stamp marked at the back of the crankcases (650SS) later on this changed to 18SS that the front of the engine number , Anything Stamped with a P on the end of a engine Number reliates to Built in Plumbstead Works London but the last 650s (IE) Mercury Model some where built at Andover in Hampshire , and may have a M stamped with the engine Number Yours Anna J
"this is information sent too me by good people in the NOC , there from the Factory records , "
So I assume you are saying "yes" the records DO show.
first two numbers are engine cases with known bikes here in the US
Last two are empty cases only, one of them I own.
Hello Well All early Machnie were sent to the USA Including the one I have,
it came back too the uk in 1998 and I had since 2006 now rebuilt, with the right silencers they did have there own there diffrent to the 650SS , And I think when they changed the 18SS to the front of the engine number was in the Plumbstead days that be 1963 on and were not sure How many Norton manxman 650s from Bracebridge Street workshop Where Built But we think some where about 608 machnies but we could be wrong ,!there is no records on how many where built it just gives a start date and a end date, And some where made for the Police in between this lot, and was fitted with 12 volt electrics , single seat and radio tank and leg shelds fitted with chash bars
. yours Anna J
