I have a folding KS on my 99 ,its from a later period and is probably a Genuine Norton. I'm trying to identify the bolt thread to obtain one long enough to reach all the threads. It appears to be 3/8th UNF, is that likely?.My stuff is all proper NORTON Bracebridge St BSF,BSC,Whitworth etc.
Just spotted some on E-BAy…
Just spotted some on E-BAy, 3/8 UNF !!, But no use without a length specified.
Check out this info for Do…
Check out this info for Dominator kickstart parts.
04-0102
BOLT
BSF
3/8"x20x1-1/2"
Do you think early ones we…
Do you think early ones were BSF, later ones UNF?
Pattern kickstarts were in…
Pattern kickstarts were invariably folding and as often as not UNF.
Looks like it must be a pa…
Looks like it must be a pattern one,definately not BSF and a 11/2" bolt is a quarter inch too short.Ho Hum,back to the layshaft which has about an 8th of an inch end float,I'm not at all convinced to shim this from the cover end .
Previously robert_tuck wrote:
