1959 Domi 99
Carrying on from my last report, I refitted my (Paul Fox serviced) K2F Magneto, set my timing (30FA-btdc-5FR-btdc on R & L) sealed and oiled, fired up and had to swap the plug leads over (Doh).
Engine runs ok on tick-over but will not rev unless fully choked, plugs show running rich, Help!, do I now have a badly worn Carburettor.
Anybody have any ideas?
Pete
You probably have restricted fuel supply, If you run on choke the plugs will soot up in a few seconds, but there will not be enough fuel to rev normally. check main jet and supply from tap and tankcap.
Thanks for the info Robert, will try and report back(watch this space)
