Can I find the history of my Commando?
Does the NOC have a scheme whereby I can determine it's history, by vehicle ID number?
Thanks,
Randy
Hi Randy,
A good place to start is once you are logged in you will find an extra menu item appears on the left called 'Records'. Start there and see where it gets you.
Previously wrote: Thanks for replying Tony - however, I think I'm myopic because I can't seem to locate the "Records" section. What am I missing?
Cheers,
Randy
Hi Randy,
Try under "Membership" then scroll down to the bottom to "Records and machine dating" Is that what you are looking for?
Previously wrote: Thanks Douglas, that worked (I simply didn't scroll down enough).
