Andover Norton brake upgrade
CAN ANYONE RECOMMEND THE ANDOVER NORTON GRIMECA CYLINDER UPGRADE FOR MK11A COMMANDO.
REGARDS JOHN
John,
Though I am not unbiased, let me put it this way: I have it on my Commando, my son Tim, who did the CAD design of the adaptor plate, has it on his, my eldest daughter's ex-boyfriend has it on his, my friends with disc braked Commandos all have it, a German classic mag tested various classic bikes that one can rent for a weekend and uttered their amazement at how good the front brake on the Commando was compared to all contemporaries because the journalist- as usual- did not realize the master cylinder was not the original one but the Andover Norton Grimeca update.
Joe
jOE
THANK YOU FOR THE RECOMMENDATION I WILL PROCEED WITH THE UPGRADE BEFORE SPRING ARRIVES.
REGARDS JOHN
Hey guys,
I have a question here. I'm not clear if the Grimeca MC from andover includes the brake lever. or if you can use the stock lever? in case it includes one is it very different to the original one?
and also, do you reckon it is a better choice compared to getting the stock MC re-sleeved?
thanks
Enrico
Enrico,
The idea of re-sleeving a master cylinder gives everybody at AP (Lockheed) brakes- for whom Andover Norton is their #1 distributor for motorcycle components worldwide- a nervous breakdown. I ordered one version of a sleeve from an English dealer- no, I won't name names- and the kindest I can say is I don't compliment him for his effort. I declined to fit it and risk my life. The Andover Norton version uses a complete current Grimeca master cylinder complete with its Grimeca lever- the Norton lever is different in many respects and does not fit that master cylinder. For pictures see http://www.andover-norton.co.uk/Accessories.htm.
I used to ride Commandos with the original master cylinder in Hamburg and Southampton city traffic in the 1970s, and even then- when other road users had nothing like the brakes they have today- the disc brake was pretty bad. Though not half as bad as a Honda CB750/4 or BMW brake, I hasten to add. This conversion performs and feels as if you got a totally different brake.
The Norton/Lockheed caliper is, by today's standarts, top of the range in that it is one piece- like today's very expensive racing calipers-, not a bolted-up assembly. Through that it is pretty strong and can, given the right hydraulic leverage which this conversion gives you, become an amazingly good brake.
Joe,
this is really useful. A lot of people told me the re-sleeving operation is the right thing to do, but it made me a bit nervous... now you're making things very clear.
Just one further detail, at the bottom part of your message do you mean Grimeca + stock Lockheed caliper makes a good brake, or are you saying I should also fit a proper (not a bolted -up assembly) racing lockheed caliper w the grimeca MC?
thanks again!
Enrico,
Sorry, I thought I made that clear by calling the standart production caliper the "Norton Lockheed", which is what is cast into it. These are surprisingly good and, as I said, of one-piece construction as opposed to the "racing" calipers that many people fit with an adaptor plate, i.e. the (originally used on Production Racers) CP2195 or the now more common CP2696 resp. the cheap & nasty pirate copy from Grimeca that is often sold instead. One piece is all the rage in racing calipers nowadays. It is far more stable than a bolted-up construction, but far costlier to produce.
Joe
thanks Joe useful hints.
For now I'll keep the stock caliper, and move ahead with the Andover Grimeca MC (but before I'd like to see one fitted on a bike - want to verify the change in look to the original...).
In the longer run I might move ahead with the CP2195, but is there a solution to fit that without using an adaptor plate?
thanks a lot
I have seen one fitted - looks good, as the adaptor plate is small and matches the profile of the fittings. I may try this route before fitting a Brembo 4 pot caliper.
Ashley
I have recently fitted the andover grimeca cylinder upgrade and would recommend it, breaking has been noticeably improvedand the kit looks good .
John
