Commando Mk.3 gearbox problems
hi , cheers tony i did not know how i could not post .
i have a mk3 850 commando that i have just rebuilt , before i stripped the bike i had a look in the gearbox as gear selection was poor , now i have the bike ready for the road i have found that i can only select 1st and 2nd gears can you tell me what could be stopping me selecting 3rd and 4th , i look farward to your reply . regards graham bell
Graham,
I presume that you have been' in' the gearbox ? If so I would remove the outer cover again and ensure that you have the Quadrant lined up properly and that the lever with the roller in it is not fouling the casing as you move it up and down. Sounds like something inside is not lined up , which is quite easy to do .
The camplate and quadrant have to be meshed in the correct position. The haynes manual shows how this should be done. Unfortunately you'll have to remove the cluster (gears, main shaft and layshaft) to allow removal of the camplate and then re-time the camplate with the quadrant.
hi, thanks for the replys , can i access the camplate and the quadrent without stripping the primary and cluch ,! i have already stripped the inner and outer cases and can remove some gears . cheers graham
