Hello,
i am new to this site and i am working on a 1972 Commando, i have purchased a Dunstall 1/2 fairing with a dash, though i do not have any idea how the gauges are held in the dash? Could anyone help?
kyle
Are they fixed in place wi…
Are they fixed in place with a u-shaped (with 90 degree corners, if you see what I mean) brackets on the back, like dials on classic cars?
Thanks, any idea of the ga…
Thanks, any idea of the gauge of metal used? and or do you have pics avaliable?
I'm sorry I don't have p…
I'm sorry I don't have pictures, but have a look at Ebay item 390345266482. It's shaped more than you really need - it just needs a flat middle section and straight sides, so is easy to make.
The back needs to be slightly wider than the instrument case, and the side 'arms'approx. the depth of the case up to the bottom of the bezel.
The middle section bolts on to the back of theinstrument (usually a couple of mounting studs or screws on the back of the case,) after theinstrument is placed in the hole of the dash panel in the fairing. The side 'arms' then bear against the back of the dash panel to secure the instrument in place.
Also see Ebay item 1108545…
Also see Ebay item 110854559069 for a variation on the same theme.
And also Ebay item 4002544…
And also Ebay item 400254487978. (I'll stop now - I'm sure you get the gist!)
Thanks, i am sure in can m…
Thanks, i am sure in can make a couple, thanks for the info
Have you tried Mighty Putty?
