Can anyone recommend someone who can repair one of the magnetic type of speedometers? I have a wavering needle which I understand is a common problem.
Also, can someone suggest a source for new/reconditioned original green dot Commando clocks?
Andy
Previously wrote: Speedo R…
Speedo Repairs in Aldershot are good. Depends where you are; UK or somewhere else? On'recons' they rarely come up from what I've seen on auction sites etc.
Hi Keith,
I'm in the UK - Forest of Dean, Glos. I have emailed Speedo Repairs for a quote. Thanks.
We list speedometer repair…
We list speedometer repairers under Instruments in the Services section of this web site
Andrew, I see that you say…
Andrew, I see that you say your problem is a wavering needle ? From what I understand this is quite normal and is caused by rough action in the drive cable or even the rear wheel drive box. I am not sure if any work on the speedo will actually sort it out. I would have a chat with Ashley Pople at Aldershot and take it from there. Repairs are not cheap and a new drive gear box can be cheaper. Having said that there can be wear in the drive head (speedo) where the cable puts too much pressure on the drive cogs. The relationship between drive box, cable and head has to be quite sweet so speak to AP for full explanation.
Cheers HET
Previously wrote: We list…
Chris The Services section…
Chris
The Services section is an excellent resource but has one disabling weakness. There is no field giving location. It takes an age to find someone nearby!
Alan
(PS Why did the software decline to add this comment above?)
I thought I would chip in…
I thought I would chip in in support of Alan, the Services guide would be much more helpful with a rough location added.
Best
Steve
