Norvil yellow paint code
I am looking for the paint code forNorvil yellow.
I believe Renault canary yellow is a match but need a code to purchase.
Think you will have better luck matching to a RAL colour and using its code, top coat gels are all RAL colours currently and no doubt that was the case too in the 70's.
What's RAL ?
RAL is a European colour matching system (similar to British standard) For instance RAL 1003 is Signal yellow, RAL 1004 is Golden yellow.
There is a complete colour charrt available if you just google RAL colours.
Ferrari Gallio Fly yellow is a near as damit colour that you require though.
Regards, Paul.
What's RAL ?
Regards, Paul.
What's RAL ?
Regards, Paul.
I used Fiat Giallo when I had my Roadster in yellow. Probably a bit stronger than the original. Not sure about the Ferrari which could be similar.
