Major missing/backfiring/cutting out when hot
Don't think it's carbs, just fitted a pair of new Amals. Starts and ticks over sweet as a nut. On a run it starts to feel lumpy after 5 miles or so. Slow down through a village or a series of turns then the problems really start. Backfires, missing, running real rough. Clears, then comes back. Cannot ride as is! I'm guessing it's electrical as it gets worse if I put the lights on.Is the spark dropping out somehow? It has electronic ignition. Fitted new plugs. On advice of a pal I checked the gap between rotor and alternator. It wasn't quite central. Gap ranged from 13thou to 3thou. It is now centralised. Good output from alternator. Battery read 11.7v when checked so perhaps not taking a charge? Charge getting to battery OK, reading 13.8v at 3000 revs.
What am I missing here? Problem defintely comes on when she gets hot.
Help!
Andy
1972 750 non-combat engine
A few thoughts :-
1)Which electronic ignition is fitted ? If there is anything suspect on charging/battery (low voltage) Boyer systems don't like these types of faults. If it is Boyer also check the stator-plate wiring (inside the points cover) - over a period of time the wiring/connections on this can get 'tired' due to heat etc. such faults can cause all sorts of mystery ignition problems.
2) It may be worth trying yet another set of plugs - I had a mystery misfire at over 4000 rpm - I had to try 3 sets of plugs to cure the problem.
11,7V is just on the low side. Normally below 12V your battery is suspect. So I would definitely try a new battery, by far the cheapest solution. You should of course check all connections. When heat is involved in misfiring always suspect any coils in the circuitry. Goes for both magnetos and coils, heat will often break a circuit, which temporarily closes when cold, i.e. broken windings and bad soldered connections.
I would suggest the carbs, as they have been changed and the problem occurs at the 5 mile mark which is just about the mark the bike is fully warmed up. Are the insulating spacers fitted, if so re-check this joint as the socket screws can come loose, especially the inner ones (modifiy an Allen key to aid doing them up)
As previous posts, the charging system seems to be controlling at a low voltage so it would be worth checking all associated connections for cleanliness and and fit, including the area where the wire enters the crimp / connector as it may look like it's connected but but may have corroded over the years.
I have checked the carbs. No air leaks possible. All joints nice and firm. Not sure which electronic ignition it is. I can't find any id on it. Coils give right ohms readings when cold. Strange alternator readings just now. At 3000 revs showing 28-30v ! 12 at tickover. Manual says should read 9. From one alternator output lead thrpough multimeter and other meter lead to earth should read zero but reading 5. Now I am really confused. Must be how I'm using the meter? It's on VAC, volts a/c. At the battery terminals with alternator connected its now only reading 12.8v . Before it has read 13.8. Hey ho!
I have what seems to be the exact same problem and have become so frustrated that I haven't used the bike this summer.
It starts off fine and after about 5 miles misfires so badly I have to keep the revs up at lights or it stalls. Embarassing. I have travelled a hundred miles on the motorway and all was OK until slowing down and having to stop at lights. (Andrew is yours OK at speed?)
I have been trying to fix it all last summer to no avail. What I have done is the following:
1. Changed the battery (it was not fully charging anyway)
2. Changed the Boyer - at least the stator and black box but not the rotor or cables
3. Did the twin carb to single carb conversion (I had the manifold) which rules out overheating of the carb because the manifold gives it more thermal separation from the engine
4. Carried out a thorough clean of the carb including the pilot jet, and tried a different main jet
5. Checked and adjusted the tappet gaps
6. Changed the coils and HT leads
After all that it hasn't idled so well in years!
I don't think think its your alternator as if you start off with a fully charged battery it should be capable of serving the ignition system for more than 5 miles even with a duff alternator.
I shall be watching this thread with great interest,
Ian
1972 Fastback
When encountering seemingly unsolvable problems like this, you will have to be more systematic in your approach. Often it will be helpful to return to as close to factory specs as possible. If you have the original points and auto-advance, try fitting these and start from there.
Over the years I have heard about so many inexplicable problems with Boyer ignitions, mind you I haven't had one, I use Pazon Surefire, which works flawlessly, that it must be one of the "usual suspects". Other than that you will have proceed by trial and error, or get a competent electronics workshop to check and measure out your components. Btw. do try a few more sets of spark plugs, I once had to go through two sets, before finding a working set.
Next trick would be to isolate the Blue capacitor out of the cct. In 17 years I have had it fail twice, first time it was blowing the fuse and the second it was shorted enough to drain the battery overnight but not to blow the fuse.
Tape up the capacitor terminals, run the bike and re-check your the voltage level on the battery terminals if it reads higher then suspect the capacitor. With a good modern lead-acid battery you don't really need it in the circuit anyway - I ditched mine years ago.
If the bike was running correctly prior to fitting the new carbs, I would be looking at the carbs. Are the carbs genuine Amal or are they a cloned item. Just because they come in an Amal box means nothing. (unless you bought them from Amal) I have had 2 friends struggle with "new Amals" and then solve their problems with genuine new Amals. Genuine Amals come in a box with the details of settings on the inside of the lid.
In my experience (ha ha) if you get a problem, it's normally the last thing you were messing with.
The carbs are the new Amal Premium carbs, from Amal themselves. I have fitted a new rotor and alternator. With a mate's rotor, no problem so I'll refit his. Battery seems ok but I'll try his as well. By process of elimination we'll get there but it's frustrating.
Are you saying that with your friend's rotor and stator, your problems go away? If so, then you have just delivered the solution yourself! Then your own generator is malfunctioning, in some way or another, and is probably not able to keep the battery topped up, and in a condition to deliver the voltage/watts needed by the Boyer. Classic Boyer condition and symptoms.
Ran bike with multimeter strapped to tank, connected to battery. A healthy 14.5v charging DC reading when riding! No problem there. Got bike really hot. No problems at all. The only thing I had done was go through all connections, HT leads etc before set off. I rode with the points cover off to keep the electronic ignition cool. Rode again with cover on. Perfect. All lights on. Perfect. DC volts dropped to 12.5, normal.
So no I have a perfect bike but no idea what the original problem may have been!
Thanks for all the advice fellas.
Always irritating to resolve a problem but still be none the wiser regarding the cause. But better to be resolved than still stumped, eh? Hope it keeps running well now.
I have just seen the post from Ian Butterss. I have spent six months chasing the same problem but only on the right cylinder. I have systematically replaced one item at a time and still would have the problem. In the workshop the bike would start easily, rev cleanly and idle well but as soon as it was ridden on the road the right cylinder would run for a short while, then cut out then run well again.
I have now finally solved the problem by fitting spark plugs one grade hotter than previous. Now the bike is a dream to ride on the road. I'm told that here in Australia it is necessary to run a hotter plug due to modern petrol.
Worth a try if you are having a problem
regards,
Ian Richtsteig
Hi Andrew
Not sure if you have rectified the problem yet. I suffered from a similar cutting out after about 3 miles. The bike re-started okay after a short pause only to run for about 40 seconds before cutting out. The fault was identified as a short within the handlebar cut out switch. The offending wire is now removed -but I have no cut out switch = and no cutting out!
Steve Brunt
I have solved my problem with overheating. Thanks for the tip about hot spark plugs Ian, but it has turned out to be faulty coil(s). When I swapped the electronic ignition I noticed on the instructions that I should have been using 6v rather than 12v coils, so I changed them as well. Now I have put in the original coils and it works a treat. The brand new ones or one of them must have been faulty. Funny that because they show no signs of bruising on the case from overtightening or anything.
Why did I have to change the ignition system in the first place?? Well in retrospect the misfiring may not have simply been due to overheating at that stage and possibly cleaning the pilot jet sorted that out, but not before I'd introduced a new fault in the coil. The main symptom was not being able to idle, but that could have been with the engine cold as well as too hot. I think I jumped to the conclusion that it was the same problem because I'd already has an overheating episode which involved bending a valve (!), which I put down at the time to sluggish charging leading to low battery voltage leading to misfiring from the Boyer.
So I have had three overlapping problems, one introduced in the course of trying to fix the others, and leaving the bike six months over winter in between times doesn't help with diagnosis. One problem at a time is definitely easier.
It really is going well now though, so all's well....
Ian butterss
750 fastback
