Head rebuild
I'm in the process of rebuilding my 750 head and replacing the thackery washers with solid spacers, problem is I can find no definitivemeasurement for the end float between rocker and spacer.
So far I've found 3 different gaps ranging from 2, 5 and 10 thou, RGM can't find any figure either, has anyone fitted spacers in the past, if sowhat gap did you use?
Steve Robinson in "Tuning the Norton Twin" recommends .002" to .005".
Hi Alan
Thanks for that wee bit of info, I think I'll go with the 5 thou gap.
