Hi everyone can you help?
I have a 1972 Commando the engine is so sweet and runs like a dream that i do not want to strip it.however the head is very dirty with white corrosion on the fins does anyone know of a way of cleaning the head?
Regards Steve
I've used a Dremmel type…
I've used those Dremmel t…
I've used those Dremmel type brass brushes too, and had mixed results. If you go at it too hard you can be left with a brassy-coloured sheen although in my experience this is more likely when cleaning up Japanese heads. Those little brushes don't last too long either and the job can get a bit expensive. I tend to use green Scotchbrite pads these days with some Solvol - messy and time consuming but I've yet to find anything better.
Hi, You could try soda bla…
You could try soda blasting (see this months Roadholder) you can tweak the nozzle to get into all the crevices, the residue just rinses off with water.
If you do try this method, take some pictures and report back.
I've used a Dremmel type tool with various brass brushes - cleaned it up quite nicely and surprisingly quickly.
