Commando Mk2a clocks
Hio everyone
Iâve just purchased a 1975 Mk2a Commando Interstate
Unfortunately, the bikeâs speedometer has the green globe design whilst the tachometer has the NVT arrow type.
Whilst both are functioning ok, I know in a short while, Iâll want to standardise both clocks.
Couldsomeone please confirm which type of clock design my Commando would have had originally, and whether itâs possible to just change the âfaceâ of the incorrect dial rather than purchase a whole new unit?. If this is possible, where would be the best place to purchase one ?
John
MK2A Interstate should have the French Vaguelia Clocks, seems the trip milage feature was seen as better for the Interstate over the Roadster. But if they were short of Vegliaclocks they would no doubt have fitted Smiths and these would be with the green globe but the later lined green globe not the earlier solid green globe.
Yes you can get the face changed as the ratios and internals are the same.
Thanks John. When you say the "French Vaguelia" clocks, are these the blue arrow ones ?. Cheers . John
Sorry to disagree but my unmolestedmk2a has the normal Smith speedo and revcounter, I would sugest it will depend on when your mk2a was manufactured.
Hi Alan
Thats interesting. I dont have the documents to hand to check exact date of manufacture( at DVLA), but I know it was definitely manufactured in 1974 as an Interstate Mk2a. The bike currently has been re-built and has a small green circle speedometer and a NVT tacho clock...
My parts book dated 1973 shows green globe pattern clocks, in both Smiths & Veglia. Part numbers & descriptions are
063790 â Speedometer head, (MPH) Veglia, C/W trip
063791 â Tachometer head, Veglia
062277 â Speedometer head, (MPH) Smiths
062279 â Tachometer head, Smiths
There are other part numbers for KMH Speedoâs
My parts book dated 1975, for MK3 models, shows NVT pattern clocks, again in both Smiths & Veglia, part numbers & descriptions are
065874 â Tachometer, Veglia, Interstate
065875 â Speedometer, Veglia, MPH, Interstate
065643 â Tachometer, Smiths, Roadster
065638 â Speedometer, Smiths, MPH, Roadster
Again, there are different numbers for KMH speedoâs & interestingly there is no mention of a trip in the Veglia, although in the picture it looks to have one.
Veglia clocks are deeper than Smiths & require a deeper instrument case/pod but Smiths clocks can be, & are often fitted to these using a pair of points cover pillar bolts to extend the mounting bolts so they reach the lugs on the deep caseâs. Most 74 MK2aâs Iâve seen have the green globe pattern & I think it wasnât until the introduction of the MK3 that the NVT pattern clocks were fitted. If you let me know which you decide to go for I can probably give you the part & model numbers for the instrument itâs self (shown on the face) so you will know what to ask/look for.
Hope this is of some help to you,
Regards, Tim
Regards, Tim
Hi Tim
Apologies for the late reply to your posting ( Ive been working away). Thanks very much for your most useful reply
Best wishes
John
Regards, Tim
Hi Tim
Best wishes
John
Hi Tim
The speedo clock is a small green globe version with "Norton" inscription and "Made in France" on the bottom. Would I be correct in assuming that the is the Veglia Interstate clock face ?.
The tacho on the bike unfortunately is the NVT blue arrow Veglia (Made in France) version, so I guessI need to look out for the green globe Veglia tacho face to make both equal ?. I understand that trying to find these without purchasing the whole tacho clock is near on impossible however ?.
Best wishes
John
Hi Chaps, just to throw a spanner in ...... I have a mk 111 registered new in 77 and it has the NVT wavy line clocks but clearly says "Smiths" at the bottom of the dial. Curiouser and curiouser !
Cheers Big Alan Clarke
Shenstone branch sec.
Hi John,
Yes, this is a veglia green globe speedo & should have the number 09190919900 after âMade in Franceâ. The tacho you require to match should have the number 09200909900.
Below is a list of speedo & tacho numbers that I have researched & noted over the years. They have been collated from many different sources including machines I have had through my workshop, internet & literature, so I make no claim that they are 100% accurate or complete, but I think they give a fairly good guide.
SSM 3001/02 1000- 150 MPH (1968-70) Solid Green Spot
SSM-3001/02A 1000- 150 MPH Green Globe Logo (best guess is that this is a replacement instrument number)
SSM 3001/03A 1000- 190 KMH (note, KMH clock but marked 1000 ?)
SSM 3001/04A 600- 240 KMH (this is from a spare instrument, original fitment unknown)
SSM 3001/09 1000- 150 MPH (1971-74) Green Globe
SSM 3001/10 600- 240 KPH (1971-74) Green Globe
SSM 4003/00 1000- 150 MPH + Trip NVT*
SSM 4003/01 600- 240 KPH + Trip NVT*
* These both have trip meters but in a Commando holder, there is no access to reset them so I think they may have been intended for Triumph Bonneville/TR7 Tiger. I donât have any info for the Smiths NVT style speedoâs without trip meters as per the parts book, can anyone help?
The 1000 & 600 at the end of the number relates to the number of cable turns per mile/kilometre, 1000 turns = 1 mile, 600 turns = 1 kilometer.
SMITHS TACHOMETERS 4:1
RSM 3003/00- 9k RPM Solid Green Spot (1968-70)
RSM 3003/12- 9k RPM (Solid Green Spot, found on Commando âSâ type)
RSM 3003/15 9k RPM (1971-74) Green Globe
RSM 3003/21(?) 10k RPM (1975-on) NVT
VEGLIA SPEEDOMETERS
09190919900 (1973-74) 150 MPH + Trip meter, Green Globe and 'Norton'
0919 091 9911 150 MPH + Trip meter (1975) NVT
VEGLIA TACHOMETERS 4:1
09200909900 9k (1973-74) Green Globe and 'Norton'
0920 090 9911 10k (1975) NVT
Hope this may be of interest to some & if anyone can fill in any gaps or add to my list I would be grateful.
Regards, Tim
P.S.
Alan,
Not so curious, both styles were available from both suppliers & by 77, bikes were being assembled from whatever parts they had to get them out the door to keep the receiver happy
Hi John,
VEGLIA SPEEDOMETERS
Regards, Tim
P.S.
Alan,
Hi Tim
Thanks for this most comprehensive reply, acknowledging that the part I need is the Green globe (Made in France with "Norton" inscription, would be part number: 09200909900.
The irony is that I only require the dial itself as everything on my tacho is working perfectly ( other than its the incorrect dial...it's the NVT one whereas my speedo is the correct green globe one). I dont suppose you know of a source where i could simply buy the correct green globe dial as opposed to waiting for a full tacho unit to become available ?.
John
Hi John,
Yes, the tacho part number you need is 09200909900. I don't know of anywhere you can buy just the face but I have had them converted or exchanged for the correct unit by A E Pople, so may be worth giving him a try, you will find his contact details here, http://www.speedorepairs.co.uk/
Regards, Tim
Hi John,
Regards, Tim
Hi Tim
Great....cheers mate
Best wishes
John
