Electronic ignition
I have a Commando 850 mkIII which I am restoring. I want to keep it original as possible but want electronic ignition. I have used boyer on the past but that was a long time ago now. Are the Boyer still good or is there better ones now that would fit in unseen?
With a mk3 to protect the starter you need a Boyer mk4 or a pazon, the boyer mk3 advances the timing at low voltages like when using a starter and the mk4 and pazon do not do this.
The Boyer Micro Digital and Boyer Micro Power (uses mini coils a for fatter sparks) are supposedly better units.:
http://atlanticgreen.com/boyerexposed.htm
http://atlanticgreen.com/boyerevolved.htm
Boyer site for above:
http://www.boyerbransden.com/microdigitalmicropower.html
Dyno Dave also talks about the Lucas Rita set up.
Finally a unit that looks extremely well made the fairly recently intoduced Wassel ignition unit: I have bought one of these for a Matchless twin...still to be renovated.
http://www.britishbikebits.com/wassell-vape-igntion-kit-triumph-bsa-norton#.WEaIPLKLSpo
http://www.grintriumph.com/images/Electrical/WasselIgnition/WW61495.pdf
Les
Read Mark Woodward's comprehensive review of electronic ignition systems for Nortons which started in Rh312, November 2013 and spanned four issues. All are available in the on-line archive accessible on this web site.
I fitted a Pazon system to my MKIII. I haven't fitted the electric start yet but have done over 500 miles since getting it back on the road in September. Mostly first kick starts, no kick-backs and superb running, especially pulling from low revs.
