Footrest rubber glue
Hi all. Any recommendations on the best glue to stop gearchange rubbers falling off with use? Obviously SuperGlue is ideal for rubber to metal but I wondered if it is too good i.e. you can't ever remove the rubber if it becomes worn. For info the bike has rearset footrests and the business end of the gear lever is smooth and constant diameter (no raised ridge at the end).
Might be the same answer but what about pillion footrest rubbers? I've had new ones fall off in normal use so these need to be glued on too.
I've always used a quick swill of petrol but that depends on the rubber being a good fit. In your case, probably evostik would work and allow later removal. Superglue can be a nightmare (and always seems to stick the bits you don't want sticking).
Have you tried just wrapping some electrical or gaffer tape around the gear lever or footrest to increase the diameter a little?
