6 O rings for the chrome head lamp bracket
Hi
Starting to assemble the bike now, new head bearings in just as advised by you guys i pulled them in with no problems.
Just fitting the yokes and chrome headlamp brackets, each bracket has 3 O rings 2 at the bottom one at the top. Do these O rings fit under the bracket to form a sort of rubber seal when crushed as the bottom yoke is pulled up, as mine are popping out on the inside of the bracket as i pull up the bottom yoke.
Or are they to be located on the outside of the bracket?
think i have solved it, tightened up the pinch bolts on the bottom yoke and all beds in Ok, with nothing popping out.
