Hi everyone,
Quick question while I'm at the bike doing odd bits.
I have noticed since fixing the clutch slipping problem, my bike has popping from 1st into neutral at around 5k rpm.
It's definitely not a slip but a pop into neutral.
Is there a good fix for this? I'm reading could be a spring issue?
Any suggestions would be appreciated. I don't plan to rebuild to entire gearbox, as the other gears are totally fine.
Rich.
the gear box I originally…
I mean 1st gear dog, I hav…
I mean 1st gear dog, I have tried to edit this but the edit formula seems so bloody confusing I don't know where the posting has gone! kind regards
If the layshaft inner bear…
If the layshaft inner bearing has been upgraded to a roller the layshaft is made floating instead of fixed, this can result in 1st gear jumping out into neutral. Cure is to shim the layshaft at the kickstart spindle. While you are in there you can check the gears and dogs for wear.
Gear box problems require…
Gear box problems require prompt investigation, worn dogs can lead to friction on the selectors which can then seieze.
5000 rpm in first ! that'…
5000 rpm in first ! that's going for it. My money is on the gear not being fully engaged in the first place. Try this. as you select first, begin letting the clutch out with pressure on the gear pedal. the gear might then fully engage. then take it to your 5000 rpm and see if it slips out. if it doesn't. the gear previously hasn't been fully selected. if it still slips out then the dogs might be an issue.
Thanks everyone. Sounds li…
Thanks everyone. Sounds like a job for the winter hibernation then.
Check Layshaft inner bearings, 1st gear dog, noted.
And yeah... I take it to 5k, but not regularly. But the bike is so nice above 4/5k, I feel like I'm wasting it if I don't ride it to full potential if I have a nice open bit of road.
Ps John. Sort of sorted that 1/8 throttle jutters. Carb clean and clean and tune and tune. It's not perfect, but it's getting there. Tho any more problems and I'm going to a single Mikuni next season.
Thanks again everyone.
Rich
The Commando box is quite…
The Commando box is quite nice and close from second to fourth - on the road it is effectively a three-speeder. It shouldn't be jumping out but I suspect that most of us short-shift from first to second and then give it some !
Main shaft first gear is v…
Main shaft first gear is very small and wears quickly, as Richard says second and onwards for spirited riding. If you do the traffic lights drag race, fit a 19 tooth gearbox sprocket.
Yeah maybe I exaggerated a…
Yeah maybe I exaggerated a little. I don't do lights drag races. But I have had the bike over 5k in 1st maybe every second time I've taken the bike out.
Was out today and did 150km with a few lads. Found my self riding 2nd and 3rd a lot trying to keep it in the band so to keep up the big boys on the 1000cc+ bikes. But manageable, even tho i was always between 4 -5000rpm+.
The 1st gear issue isn't massive (for now), but it's good to know that it's a known and solvable issue.
Thanks again
Rich
Keeping up with the big bo…
Keeping up with the big boys on 1000cc+ bikes on a 40 year old bike. Best budget for an engine rebuild to go with your gearbox.
Hi everyone, Sorry to brin…
Hi everyone,
Sorry to bring this topic back up.
I got a new answer to my 1sr gear problem and want it cleared up, as I don't really understand the answer in reply. Can someone explain this to me a bit more?
"Bike jumping out of first sounds as the quadrant is wrongly positioned by 1 tooth, so does not have the full way in the "window" of the gearbox inner cover. Which means it NEARLY engages the gear but not quite and uinder load it jumps out again."
Perhaps give me an insight as to how to fix according to this answer?
Cheers.
Rich.
I think that what he is tr…
I think that what he is trying to tell you is that when you engage first gear, the gears are not being fully engaged. Then, when you try to pull away the pressure on the gears causes then to disengage themselves.
Check the engagement like Richard says.
Ok i can answer this with…
Ok i can answer this with regard to the cam plate, to get to the cam plate you have to take off the outer cover followed by the inner cover, so if you have had the gearbox apart there is a chance the cam plate is a tooth out, i know i made that mistake and found i could only select 2 gears with the others sort of engaging.
If your bike was selecting gear ok and the gearbox has not been stripped imo its not the cam plate.
The window referred to can be seen once the first cover has been removed there will be a fork facing you (quadrant) with a lose barrel with a hole in, that the gear lever engages (knuckle pin roller). When you select gear the fork will move up and down and must go to both extremes of that window.
if the gearbox has been apart and you need to move the quadrant by 1 or 2 teeth it can be done without taking the sleeve gear out.
the gear box I originally had on the G80cs would slip out of first gear to the extent in reallity it was only a 3 speed box, the problem was wear on ist gear dogs, once this gear was replace the box worked perfectly, it certainly wasn't doing 5K when this happened though. kind regards
