Hello all, looking to rewire my 72 Commando anyone got sources for wiring cable etc.
Can anyone tell me the wire size ie dia.
Cheers all.
Best place that I know of…
+1 to that â they're not…
+1 to that â they're not cheap, but you get what you pay for with them, and they have most if not all of what you want. I tend to buy wire by amperage suitability, with a rule of thumb that, within reason, a wire that's a bit thicker than you need is good. I know, really technical of me â?
Why not use Al Osborne the…
Why not use Al Osborne the club electrical specialist, as well as excellent service you get free advice!
I always used to use VWP b…
I always used to use VWP but more recently Autosparks who are slightly cheaper and have just as good products.
https://www.autosparks.co.uk/index.php?content_page=51
I use 16.5 amp thinwall 1mm2 cable which is easily capable of running anything on my ES2 although you may want to go up a size for the charging system on your Commando. The only problem I find with the thinwall cable is that the insulation melts more easily than the conventional stuff when soldering.
Previously Dan Field wrote…
Thanks Dan â to be honest, I had no idea!
Cheers lads used Al years…
Cheers lads used Al years ago thought he had retired, been out to the garage tonight to start winter strip down bloody cold out loved it
Nope heâs still here and…
Nope heâs still here and often on this site! or can also be found here:
dan
Best place that I know of ;- www.vehicle-wiring-products.eu
They are in Ilkeston Derbyshire
