wiring
Hello all, looking to rewire my 72 Commando anyone got sources for wiring cable etc.
Can anyone tell me the wire size ie dia.
Cheers all.
Best place that I know of ;- www.vehicle-wiring-products.eu
They are in Ilkeston Derbyshire
+1 to that â they're not cheap, but you get what you pay for with them, and they have most if not all of what you want. I tend to buy wire by amperage suitability, with a rule of thumb that, within reason, a wire that's a bit thicker than you need is good. I know, really technical of me â? Tongue out
Why not use Al Osborne the club electrical specialist, as well as excellent service you get free advice!
I always used to use VWP but more recently Autosparks who are slightly cheaper and have just as good products.
https://www.autosparks.co.uk/index.php?content_page=51
I use 16.5 amp thinwall 1mm2 cable which is easily capable of running anything on my ES2 although you may want to go up a size for the charging system on your Commando. The only problem I find with the thinwall cable is that the insulation melts more easily than the conventional stuff when soldering.
Thanks Dan â to be honest, I had no idea!
Cheers lads used Al years ago thought he had retired, been out to the garage tonight to start winter strip down bloody cold out loved it
