Gearbox mainshaft wear limit
Hello, does anyone know if there are any measurements for the wear limit of the gearbox mainshaft where the sleeve gear bushes run? I can feel a slight reduction in the shaft diameter.
Also I've read in our technical section the recommendation to change the layshaft ball bearing to a roller bearing, with mention of the requirement to shim the shaft to roller inner race to achieve the correct end float, what should this be?
https://www.nortonownersclub.org/forum/excessive-gearbox-layshaft-endfloat
Thanks John, plenty to go on there and the final comment has me now wondering if it's worth the effort, as MH wasn't a fan of the conversion.
As for wear on the mainshaft, I guess none is the most desirable and renewal the only solution.
