Having recently acquired a good hub to replace my damaged one, I eyed up the job on the existing wheel and noticed the spokes look stressed. Can anyone please confirm if they think the rim pocket holes are at the wrong angle, or possibly the spokes and nipples could be the wrong diameter?
Thanks Peter, the spokes and…
Thanks Peter, the spokes and nipples do look a bit chunky. It's a pity as they're nice stainless ones too. I'll get the verniers out to measure them.
40 hole rim pattern
Hi Adam
I have not got the answers for you, but I have a clue on what to ask when you talk to a wheel building expert. 40 hole rims come in 'Norton' pattern and in 'other bike' patterns. It might be that this is a 'other bike' rim and a wheel builder has forced the fit onto the hub.
Hi Adam, the MC275 is a for a front disc wheel not sure it would
Hi Adam, the MC275 is usually for a front disc wheel, rear would be a MB41 or MC286, I would take advice from a reputable wheel builder before proceeding. Best wishes, Terry.
Looks to me as if someone…
Looks to me as if someone has bent the spokes in an effort to take out some built in slack seeing that some spokes are bent in one direction and some in the opposite direction.
Hello Terry, I took your…
Hello Terry, I took your advice and spoke to Devon Wheel company and they identified the rim and spokes I need. Just received them yesterday so I can get started on the wheel build soon. I've been reading up on wheel offset and the guidance looks to be to have the rim centered between the swinging arm tubes.
I'm looking forward to having a steady speedometer, which is how this all began after finding it's erratic needle movement was caused by the cracked wheel hub.
Rear wheel
Hi Adam, glad to hear you're getting the wheel sorted. If you want offset figures RGM have a list on their website under "technical tips, help & instructions" located at the top of the website page. I also have an original wheel I could measure for you. Best wishes, Terry.
Thanks, I've just had a look…
Thanks, I've just had a look, there's a load of useful information about everything on there I didn't know about. As for the offset, they've recorded a 1/4" from the offside hub face. I'll set it at that and give it a try, I can probably reset by re-adjusting the spokes while the wheel's still fitted to the bike if it does anything weird.
Looks like the nipples are too tight a fit in the rim holes, (so the nipple can't align with the spoke) or whoever built the wheel got the lacing pattern wrong.
The worst example i've seen, of this kind of thing was on the front wheel of a 350 Manx, the spokes had a nasty bends in them to line up with the nipples. It was lucky the owner kept the bike as a museum piece and didn't ride it.
