I am trying to find a pair of of unbalanced pipes for my Mk.3. I have a pair of pea shooters I want to use.
I'm having trouble finding a suitable set.
Any help would be greatly appreciated.
Try L.F. Harris https://www…
If you want to change from…
If you want to change from the standard Mk3 exhaust set up to pea shooters you will also need to change the brackets as well as the exhaust pipes. There are plenty of sources of the pea shooter exhausts as mentioned above.
Try L.F. Harris
https://www.lfharris.co.uk/product-list?productId=16263&categoryId=18&parentId=1
You might have to ring them and find out who they supply these to as they only supply the trade.
