Hi - is there anyone in Hampshire, Dorset or Sussex who would kindly lend me this tool (ET2003, NOC part number 067524). I'm desperate! Thanks
I am in Berkshire if that is…
Hi Tony Many thanks for your…
Hi Tony
Many thanks for your kind offer.  Following advice I'm going to have a go at removing the bearing first to, I guess, gain access with a normal puller.  If I fail I may well come back to you!
Terry
Complete strip down?
Are you stripping the engine completely?   If you are, the way I removed the half time gear was to heat up the crank case up to remove the main bearing along with the crank shaft and the various parts on that end of the crank.
Then I was able to shift it without the need for a special puller.
Completed strip down
Hi John
Many thanks for this - I am doing a completed strip down so will attempt to remove the main bearing and have a go.  Now waiting for delivery of a blowlamp!!!  Your advice much appreciated.  Cheers
Terry
main bearing released from crankcase
Hi John
Got the blow lamp and have removed main bearing from crank case.  Its now on the freed up crankshaft.  But there seems to be no space behind it to get a puller on it to pull off the bearing complete with half time pinion.  Am I missing something here?
Terry
Crankshaft oil feed end
Terry,
Not sure where you are getting your advice.. The Norton Twins workshop manual is good.
It advises very strongly you put a tube over the crankshaft end, and to hit that with a hide hammer if necessary to get crank out of crankcase timing side. Belting the crankshaft end with a hammer nearly always swells the crankshaft end and ruins the oil sealing surface.
The manual also advises the proper half time pinion extractor, which I believe is common across lightweight and heavyweight twins.
I hope you are successful.
Hi Peter Many thanks for…
Hi Peter
Many thanks for your advice - will follow your instructions.  Help much appreciated.
Terry
Why not....
... just buy an extractor from the NOC? You can always sell it on later. And you may find you need to remove the pinion more than once......
Hi Ian thanks for this - may…
Hi Ian
thanks for this - may well end up doing this. Just hoping I only have to remove it once. Forever the optimist!!!!!!
Terry
Home-Made-Puller-Tool
I made a pinion puller for my Dominator by grinding the heads of three coach bolts to fit the triangular washer.  I only needed two bolts in the event.
A drilled alloy plate and Jubilee Clip was used for the holding the bolts in position.
Carefully directed heat was enough to slacken the pinion and allow it to be eased off.
Home made puller tool
Hi Phillip - many thanks for this.
What an ingenious solution!  May well try this if I cant get the bearing out.
Terry
I am in Berkshire if that is any good. 60 miles from you.
RG7 3HP
If you wish to pop up and borrow it, send me a PM.
