Atlas carb settings
Hi all, Canada calling. I have taken over finishing a project started by a good friend who has passed away. This to complete the project for the family. Being a Commando man Monobloc's are a new venture for me, and there are two questions I need help with.The Monobloc's are 1 5/32, with velocity stacks. The needle jet is numbered 1065, is this correct? The pilot is a 20 and main 350. Also can you tell me what notch should the needle be positioned in? I do not know the c.r. or what cam is in place. Thanks for your help.
!065  is OK . They are sometimes marked 106  (but are actually 1065) . They are very prone to wear and should be replaced every  10,000 miles approx. pilot may need to go up a size or two. Try the middle notch on needle.
Many thanks Robert, mind at rest, I can now proceed. Tony
